hi,i am currently have 4 scripts already on uc520, and i can't add another one ( it reaches the maximum limit). what is the limitation on the script, and how do i add more scripts when it reaches the maximum limitthank you
I just installed 10 SPA525G’s using 802.11 wireless network using the UC540W and AP541. One of the phones is experience one way choppy calls. The wireless signal is great and is next to a phone that is not having an issue. It seems that the callin...
I am installing a UC540 using a One Communications sip trunk. My customer has multiple companies and would like to know which is being called, when answering the phones. My plan was/is to create line appearances on the phones for each company. Howe...
i have a uc 520 with cme 7.x i have spa504g phones but they will not provision. please help
We are deploying 5 UC500s - 2 UC560, 3 UC540W in 5 different locations. Each of these locations will have a direct internet access via the WAN port of the UC500 as well as a MPLS router on the LAN to route traffic destined for the 4 other branches. ...
Is here anybody knows If the UC500 support two auto attendants in one or two ports at same time?
Hi!I am using freeswitch to connect to my SPA3102 which is registered using TLS. Quite often I see the following, which results in FreeSwitch ending the call with NORMAL_TEMPORARY_FAILURE.The syslog from the SPA3102 looks like this:Mar 19 19:58:15 x...
we are routing voip calls between two offices using an UC520 at each site. The UC520 in each site has a T1 connection to an existingAvaya PBX. internal users are able to do conference calls between offices. When external calls come in to either offic...
Hi, I've just purchased a UC540 unit from Amazon. Do I need to purchase a service plan for this device to get access to the CISCO download center(for any software updates) ?Do I need the service plan to get updates for the device?
Hi CommunityIs there a end-user manual/guide in Danish for the UC500 serie (520/540/560)
Hi,It's possible to configura a line key 1 with an extended function likefnc=blf+sd+cp;sub=200@172.18.20.22;nme=Ext 200in order to monitor the extension 200 without an attendant Console?I did it on an spa942 and spa962 but i don't know if it's possib...
I applied the latest release of the Cisco firmware (7.4.6) last night and have come across an issue. The phones are not fully applying some of the configuration parameters specified in the provisioning template we use even though the settings show up...
What commands are required to configure CUE IP address, loopback interface, gateway, etc. before doing a factory reset. My IP address has not been set for the CUE so I can't issue the standard factory restore commands without getting an error.These w...
Hi All,I have a customer that prefers to answer all of their calls live and back it up with an Auto Attendant. I have setup up a call blast group that times out (after about 10 rings) to the AA and have set the blast group as the destination in the i...
Hi,Had a small incident with an SPA508G that has landed it in the "SOS Recovery Mode". It currently has the message on the screen and all 3 buttons at the bottom lit. All the recovery documentation says there should be flashing lights... I don't have...
