Security
Explore the security forums and share your expertise about firewalls, email and web security, Identity Service Engine, VPN, AnyConnect, Duo, Umbrella, Secure Access and more.
Browse the Community
Network Access Control
Network Security
Engage with peers and experts on network security topics such as Secure Firewall Threat Defense, Ada...
Duo Security
Get started with or get better at administering and using Duo by interacting with peers and experts!
OpenDNS
Ask questions not covered by support articles and documentation.
Activity in Security
ASA 5525-X ver 9.14.4.23 Anyconnect software
Hello all, I wanted to see if anyone knew if i am able to download and push the newest secure client software on our older ASA. We currently use anyconnect ver 4.10 and would like to get this higher prior to our migration to FMC. I only see Secure Cl...
LDP by Frequent Visitor
  • 79 Views
  • 2 replies
Resolved! Duo Gateway Authentication Options
I am running an implementation of Duo on a Virtual Desktop Environment (VDI) that uses the Microsoft Desktop Gateway App to perform 2FA on a broker/session host. I understand there are only two options with this implementation: Duo Push, and Phone Ca...
akond by Community Member
  • 280 Views
  • 10 replies
Cisco ISE
Hello, i get the message when i try to test the connectivite between my switch and ise:Attempting authentication test to server-group ISE using radiusNo authoritative response from any server.I assum that the cnfig in switch is correct and i can reac...
abderrahman by Frequent Visitor
  • 117 Views
  • 3 replies
Policy for Network Subnets in Secure Access
Hi. Does Cisco Secure Access supports creating a policy for internal networks that associated with network tunnel? For example, the subnet for IOT devices is 192.168.x.x/24 and for guest users is 172.x.x.x/24, and I wanted to create separate policy f...
Resolved! FMC 7.6.5 remote backup failing
Hi,We have 5 FMC servers which have been upgraded recently from 7.4.2 to 7.6.5. I found out that since then the daily backup of the FMC server towards a Linux server (Ubuntu 20.04) is not working anymore. The firewalls are still running on version 7....
johnslegers by Community Member
  • 97 Views
  • 3 replies
Features Confirmation
Hi Cisco Secure Access Team or any folks here that encountered this kind of requirement. Would like to confirm whether the following security features are supported by Cisco Secure Access:User Identity Binding to Device HostnameThe user identity shou...
Network Already Exists
Hello OpenDNS/Cisco Support,I am experiencing an issue with my OpenDNS network configuration. When I try to add/register my current network, I receive the error “Network already exists.”My existing OpenDNS network is currently listed under my account...
bryle-euro by Community Member
  • 95 Views
  • 4 replies
Migrate FPR 2100 to FPR 3105
I am trying to migrate FPR 2100 FTD to FPR 3105 FTD. Both of them are managed by the same FMC. The FPR3105 has only one configured interface: the management interface. When I use the migration from the FMC, it fails after mapping the interface. Any r...
D346 Duo Release Notes for September 3, 2026
Hello everyone! Here are the release notes for our most recent updates to Duo. Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out to commercial deployments. You can su...
dashboard_widgets_with_buttons (1).png Screenshot 2026-08-27 at 11.09.18 AM.png Screenshot 2026-08-27 at 11.16.46 AM.png Screenshot 2026-08-27 at 11.18.58 AM.png
Rick Wong by Cisco Employee
  • 1166 Views
  • 6 replies
  • 1 Helpful votes
ISE Guest with FlexConnect Local Switching
I'm working with a customer with around 50 locations and they do not want to centrally switch any traffic, including guest.  The challenge is that in WLC 7.5, the behavior of how radius-applied ACLs are used was changed.  In the WLC, you can manually...
Issues-DUO in Splunk (Empty Location Details and Incorrect IP Field)
Hi Team,We have successfully onboarded DUO logs into the Splunk SIEM platform. We are polling the DUO API to retrieve the necessary logs and have installed the Splunk DUO Add-on to extract the required fields.While all the DUO logs are being ingested...
varun-kumar by Community Member
  • 1102 Views
  • 2 replies
Top Experts - Last 30 Days
