Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,Everyday I receive the following error message a couple of times a day:eth0: received packet with own address as source addressRouter Config info:Firmware Version: V2.0.1.3Signature Version: 1.42Does anyone know why I ...
I have 13 WAP4410N and I have the same problem.
Question, for the AP541Nwireless AP, what POE injector are you supposed to use?The web site states any enterprise class af POE injector will do, but the AP1131 POE injector does not work with the AP541N.Thanks!Jeff
I have both working in a cluster and traffic is flowing but now I desire toseperate my intranet from internet guest traffic only. Having an issue with understanding how to accomplish this task. I have one 2003 server in the intranet that supports DHC...
Hi,I wonder if there is any place in WRVS4400N where I can tell it to just be an Accesspoint?I have a customer who have 8 sites and we don´t know if there is enough with one wireless router or if we need some AP as well.If it´s possible to make the W...
In 2.0.3.3 software version for WAP4410N the syslog feature to send messages to external server is broken.To correct this issue you have to connect to the AP via ssh and do:# killall syslogd# /usr/sbin/syslogd -R x.x.x.x:514 -f /tmp/syslog.confWhere ...
I successfully set up my WVC210 wirelesss camera, but I couldn't get get the email alerts to work. I understand it will not work with some emails systems like gmail. Does anybody know which type of email will work or how I can get gmail to work?Thank...
I just managed to get hold of an old second hand WAP4410N from a friend who got it for work but never really had the time to get it working. I powered it up and performed a 30/30/30 reset to get rid of anything he may have done to it but now I'm stru...
Could any of you provide feedback about the WAP4410N wireless access point, and its reliability, I heard it has intermitent connectivity problems, and saw some bad comments in the Cisco Small Business support Community, but I would like to check if...
Hi all,I have just installed a AP541N-K9-1.9(1) access point at my office.I bought it new in the UK from a major retailer.Under wireless settings > country selection, there is no UK option. I have upgraded the firmware to v1.9.1 but there is still no...
Hi,We have 10 WAP4410N accesspoints and we want to do authentication on a Windows Active Directory server. Could somebody explain me how to do this or point me to some documentation by which we can do this? Only users in the Windows AD need to get ac...
I have a WAP2000 conected to a PIX 501 pulling the net from a Charter account via the Charter provided modem. PIX tunnels to our main office via the net. The wireless connectivity is inconsistent. The wired network is working as it should. WAP is se...
Hello,I have a current network setup using the RV042 as the primary router (DHCP server). I purchased 2 WAP2000 Access Points with the hope of setting up two wireless networks for client and guests. I thought that the RV042 supported VLANs like it'...
I was wondering if anyone knows what the low, medium and high power settings on the AP541N in dBm are.The data sheet indicates what the maximum /Full power setting are:Available transmit power settings (maximum power setting will vary by channel and ...
HiI am trying to use some WAP4410N in client mode, not much luck.In one case they shouldt connect to different unsecured networks controlled by a Cisco 5508 controller.I can get connection to one of the SSID's but not very stable.One ssid can be see...
User | Count |
1 | |
1 | |
1 | |
1 | |
1 |
