Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have a Cisco WRT320N. I want to use it as a repeater, because my NETGEAR router isn't quite reaching my office desktop across the house. I don't want to use a cable in between the routers. I want to set up the Cisco router somewhere in the house, r...
Hi All,I was experiencing issues with Android devices connected via WiFi not roaming when a stronger SSID is available and having found a fix for my issue thought I'd share it on the community.Problem: Basically Android stays connected to an SSID for...
Hi allin a scenario i got 6 AP all are Cisco WAP321 with one SSID (its all in 1 cluster) and everyone in the office roaming around working fine :Dnow i need to add 4 new Cisco WAP321 access points to cover the 2nd floor. and i was wondering,if its no...
Hello all, I have a client with a UC540 and when they try to download anything of decent size it causes all the wired phones to get busy signals and calls cannot come in. The phones are SPA508G and there are 5 of them. Once the download starts the ph...
Hi,I have a WAP4410N that I am trying to get to work on multiple VLANs. Here is the scenarioThe WAP is plugged into a cisco switch. The port on the switch is trunked. I have 2 VLANs on this network VLAN 1 for business and VLAN 2 for guest access.I ha...
Hi,I have a WAP371-E-K9 V01, but I noticed I cannot select WiFi channel 13 (or any above 9) in the WiFi settings.Channel 13 is legal for use in the UK. How do I tell my AP that I'm in the UK?Thanks,Matthew
We have deployed WAP551 in a few offices in our building, and I've started to think it was a big mistake. Our configuration: Each office has about 25 users on it's own subnet, with DHCP. Within each office I have (3) three WAP551's in a cluster. B...
I've recently began testing a WAP371 with firmware 1.0.1.5 working from an at POE injector. I'm having a problem with a Sony Vaio laptop that uses an Intel 7620N dual band adapter which seems to work fine for 24 hours then starts losing connection ev...
I just purchased 3 WAP371's for a busy medical office (6 DR's going from exam room to exam room with laptops)I intend to set them up with Single Point Configurations.Can I name Radio 1 and Radio 2 the same names? Also, can they both share the same W...
Just wander if somebody could help me to find answer for my problem. I mark IP packets on device connected (laptop’s WiFi NIC) to WAP 371 with DSCP 46 – so packet which ender AP is marked with Expected Forwarding value. Do I need to do anything else ...
According to Bug ID: CSCuq93941There should be a fixed firmware for download as per 6 Jan 2015. This firmware doesn't exist in the provided link nor in the download firmware section for WAP371. Can you please update the download section with the new ...
We purchased 3 several WAP121 E K 9 with f/w 1.0.5.3 and the time resets to either a date in 2009 or 2011 after power off or reboot. Any suggestions. Supplier has asked we contact Cisco Support
Hello community,i had a question over WAP 121 / 321 series.I would like to use more of this APs with 3 Networks (vSSIDs). So i enter the vSSIDs in the first WAP 121 now i would like to repeat all the vSSIDs with a second or third auf this APs.Is this...
I have three WAP321s and one of them has become unresponsive. When plugged in via PoE, the power light glows solid orange, the wireless light is off, and the LAN activity light blinks. According to my switch, there is also activity on the port as w...
