IP Telephony and Phones
Labels
Currently Being ModeratedPublisher vs SubsciberHi,In a scneario of Publisher & Subscriber......if say all the phone are registered with Subscriber and Subscriber Goes down so what is the effect on IP Phones or will all features work properly.pls sug...
Hi,We have implemented Mobility in our cluster. We are struggling with the dial plan using the mobile phone address book. Most of the numbers are saved starting with +44, If we try to call the call is unsuccessful. We cant have a route pattern starti...
Dear All,is there a way to limit call duration on the each extension and if any extension exceed the determined limit ,the system send alert message indicating that you exceeded your limit and  drop a call or do any action .i have UCM 5.x,Unity 4.xth...
We have the attached setup (attached)  that we have local H.323 network, which includes Cisco 3845 (Gateway), Cisco CVP 3.1 (IVR), Cisco Call Manager and IP Phones.The gateway was having PRI ISDN Ports and was working fine end-to-end. Then we needed ...
luai by Level 1
  • 1014 Views
  • 0 replies
Hi All,We are trying to push ring volume to our ip phones. Let's say that there are different levels of calls that are triggered by a own written application, this application handles several actions, and when action 1 is activated, several phones sh...
p-vincent by Level 1
  • 670 Views
  • 4 replies
I'm interested in formatting the caller ID information that comes in from our PRI.  I've received requests to make the output more readable for the users.  When a call comes in, we see "1234567890".  I would like it to show the same number, but show ...
We have timed partitions setup at a school that only allow calls to ring classroom phones before and after classes. It is working. If for example you would call DN 2010 during class hours it would hit a CTI Route Point with the same DN (2010) that is...
johnnywan by Level 1
  • 307 Views
  • 1 replies
