IP Telephony and Phones
Labels
Hello Guru,after MGCP fallback to SRST, what is the timer the SRST router back to CUCM? immediately? or some delay?if it is immediately and if WAN link flaps, will the T1 D channel flap as well?
Hello,I'm having problems completing fax calls. I have these dialpeers configured:dial-peer voice 9999 voip incoming called-number #1.......... dtmf-relay rtp-nte fax-relay ecm disable fax rate 14400 fax nsf 000000 fax protocol t38 ls-redundancy 5 hs...
Hi all,We have a CCM6 cluster with 2 servers, Auto Registration is enabled on both of them. The auto registration function was working well until 2 weeks ago. Now the new ip phones could not get registered automatically (we must add new phone manuall...
hoanghiep by Level 1
  • 401 Views
  • 1 replies
Hi,We have two types of users:1.Users who can dial any number including International (00) & (0)2.Users who can dial mobile (050) & national numbers.Now we want to configure PINs for both the users.What are the configurations required.A template woul...
