IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6556 Views
  • 14 replies
Hi everyone,I have some question on unity:1, For configuring call transfer options on the User menu, there are two transfer type, that is 'Release to switch' and 'Supervise transfer'. I know Supervise transfer let unity play greeting when the phone i...
hetao1601 by Level 1
  • 679 Views
  • 4 replies
Hello Experts,Our subscriber reboots every two or three weeks while the publisher is always up & running. I am looking in the Syslogs using RTMT tool to find out the reason but don't see any messages regarding the reboot. Is there any specific place ...
Hello,Right now I have this access list applied to my Cisco GW:access-list 100 permit tcp host Y.Y.Y.Y host X.X.X.X eq 1719access-list 100 permit tcp host Y.Y.Y.Y host X.X.X.X eq 1720access-list 100 permit udp host Y.Y.Y.Y host X.X.X.X eq 5060access-...
i have a question sorry i still beginner in VOIP network, if we use SIP at 2 gateway and each gateway will connect with ip phone (SSCP) what will happen or what is the procedure that will happen to make call ?
Hi, I have configured a gateway h.323 (E1 on Router 2801) and weekly happens that not works transfer. Then also the outcoming call is not possible. The logs indicate a problem on mtp (MtpNoMoreResourcesAvailable), but I,' ve few IP-Phone (about 50 i...
ribola by Level 1
  • 1081 Views
  • 11 replies
