IP Telephony and Phones
Labels
I am trying to route our international calls from London to NY over our IP network. Call flow from London will be: Nortel Meridian > PRI card > Cisco Gateway PRI Interface > TDM to RTP conversion > Into QoS enabled London LAN > Via MPLS Network > Int...
looking for information to help understand flex mode dsp. If I have local hardware conference between local & remote people (711 &729 codecs), does the flex mode provide transcoding, or do I also need to set up transcoding? thanks
hello i have call manager that is connected to PBX via BRI of 2811 gateway, the problem is when some calls between Cisco IP phone and the phone that is behind PBX does not pass, and it dipslays an error message.In attachment you will find trace of th...
dbenattou by Level 1
  • 313 Views
  • 1 replies
Hello all,I have a project starting tomorrow with linksys SPA922 sip phone and Call manager 5.x. I have started playing around with the setup but the phone's registration is rejected. Can you please point me to the right direction for documents that ...
jkofosu by Level 1
  • 423 Views
  • 1 replies
