This is very high level, wanting to know if this is possible. We're the middle man. I don't have access to or knowledge of equipment or configs on the other providers. Currently we are handed off a GRE tunnel to a router. We have an ipsec tunnel ...
The content you are looking for has been archived. View related content below.
Please refer the below topology,Client >>> Cisco router >>> Firewall >>> Upstream device >>> serverI have set mtu as 200 in my upstream device and as exepected when client access the server(http) the packets are fragmented.However when I set tcp-ms...
I went thru and added the followingexisting eigrp:router eigrp 99network 10.76.0.0 0.0.0.255network 10.76.2.0 0.0.0.255network 10.76.10.0 0.0.0.255network 10.76.200.0 0.0.0.255network 172.16.0.0network 192.168.10.0redistribute ospf 99 metric 10000 10...
Hi, i have a switch 2960 24TC-L with c2960-lanbasek9-mz.150-1.SE.bin and SSH v1 enabled.When i try to enable SSH v2 the swith tell me that i have to create a crypto key rsa. I generated the crypto key rsa with 1024 bits and when i try to enable the S...
Introduction: This document gives information about DMVPN with a configuration example. What is DMVPN? DMVPN stands for Dynamic Multipoint VPN and it is an effective solution for dynamic secure overlay networks. In short, DMVPN is combination of ...
Hi, can anyone please advise how to change ASR 1001 router interface speed from default to speed 100? I can't find the command speed under interface config. thanks in advance!
i have Cisco 9901 with IOS XR Configuration 7.9.21 some protocols can't appear with me like isis below issue appear for example, I need router ISIS configurations but below I can't find isis option (config)#router ? bgp BGP configuration subco...
The ISR4451 router is based on the XE system, and it is not possible to configure a bridge group under the interface in this system. I have found the configuration related to the bridge domain based on the XE system (only related to Ethernet interfac...
Hello,i have an ISR 4431 Router with broken flash. The device has been registered with Cisco but i have no additional contract.According to the chat support, there is no way to download again the IOS delivered with the router?Any idea how to do this?...
Hi The DMVPN tunnel was reset, which caused the BGP session to reset as well. We observed that the DMVPN crypto socket is down. What could be the issue? We suspect it might be related to the ISP, but they have reported no abnormalities in their logsD...
I have a Catalyst 2960-X model switch with the port 3 and 4 led blinking green ( communicating ) and suddenly starts blinking orange for a few moments and then flashes green normally. It's been swinging all day. Thank you
Hi,I have upgraded my Cisco Nexus C93180YC-FX yesterday from NXOS 10.2(6)M to NXOS 10.3(4a)M, but I seem that I have an error when I make "sh logging last 10".2024 Apr 30 09:39:09 edge01.par03 %DAEMON-3-SYSTEM_MSG: error: Unable to open the btmp file...
Hello, I am asking myself what others recommend for the connection between core switch and Firewall. The setup is the following:Two Catalyst 9300 Core switches in stack. The stack is connected to two Secure Firewalls 3105.The Core is doing L3 routing...
in the shown design , why the PC connected to R1 can't ping to the last PC , while R1 can ping to the last PCnote : The PC connected to R1 already configure the default gateway R1
Hi AllIf we have 3 routers, A, B ,CA has an IBGP peering to C, B is just running ospf so each BGP speaker can learn its neighbours.I hear that if a packet comes into A, it still has to go via B, when it hits B it will get dropped.Why is this? as the ...
Subject | Author | Posted |
08-07-2024 10:40 AM | ||
07-15-2024 05:07 AM | ||
07-13-2024 09:04 AM | ||
07-09-2024 05:41 AM | ||
07-03-2024 08:54 PM |
User | Count |
12 | |
10 | |
8 | |
3 | |
2 |
