Hello, I am picking a router for internet connectivity. All I need is NATing, Static routing , VRF, IPSEC. I am planning to go for C8200-1N-4T. Bit confused whether I need DNA Advantage license or Essential is more than enough ? Please suggest
The content you are looking for has been archived. View related content below.
I just unboxed a new 3925 V-Sec. I've tried admin/admin, Cisco/Cisco, admin/blank, cisco/cisco, admin/cisco, you name it; nothing on my list worked. Any ideas? Thanks Roy
We have a static route set on a pair of Nexus 9k (Connected with a VPC ) for a subnet pointed to our Palo Alto FW. We have numerous other static routes to the same IP. For some reason, on only the second 9K, this particular static route for ONLY this...
So I have had a few 4351ISR units that will not enter password recovery mode. My steps are below:Power on the routerPress CTRL-C until it enters ROMMONAt ROMMON1> confreg 0x2142at ROMMON2> resetThe router reboots and asks for user name and password. ...
Hey, reading through the datasheet for the Cisco 8000 Series Secure Routers. I keep seeing this reference to something called 'EMIX' when discussing security and threat related technologies and features. See this article and Ctrl+F for 'EMIX' Cisco ...
Hello I have a working system coming from another Thread which was solved but now I am curious if how I got it all to work was correct or a forceful band-aid. https://community.cisco.com/t5/routing/can-not-get-internet-access-or-nat-translations-on-...
Hello all,Diving into the PIM "routing protocol" and have a few questions:PIM neighborships - if PIM does not send out any routing updates to its neighbors, what is the point of a PIM neighborship? (In my packet captures, all I ever see are PIM "Hell...
I have a setup whereCE1 connected to PE1CE3 connected to PE3PE1 and PE3 route reflector clients to RR.I have set the local preference for all CE1 routes to 200 on PE1.Later I have set the community for CE1 routes to 65000:101 I can confirm that PE3 ...
Good day team\collegues!Today I've upgraded cisco C8300-1N1S-6T to 17.15.4cIt has been deployed on 29th September https://software.cisco.com/download/home/286324476/type/282046477/release/IOSXE-17.15.4cI've converted to INSTALL mode and next is to in...
I have a new C8130-G2 router. This is my first experience with this platform. We are using this for some simple routing at a branch site. So no need for Advantage Routing license or SD WAN license. We are planning to just use the default Essentials R...
Hi all, I'm posting for a group of students attempting to make a network for a class. We currently have a Cisco 2811 router we are configuring. We can ping within the local network but we can't seem to ping to the internet. We have tried everything w...
Hi, i would need some help with proof of concept. We have 2 sites and we want to use QINQ. We want the Provider to be the one adding and removing the outer tag. So for ingress, the Provider add the outer tag ex 4000 and before it sends it out egress...
Hi team, Besides the WAN ports on the IR8340/K9 device, the LAN ports also support routing (can operate at Layer 3). Thanks team
Hi All, I am performing a migration from a Cisco C6500 to a Cisco C9600 for a customer.In the existing C6500 environment, multiple Policy-Based Routing (PBR) policies are being used along with tracking.I could not find sufficient documentation relate...
I have one Router Cisco Serie 2500 Model 2511. This device cannot boot. If someone has the iOS image to recover it. Please can you give me the solution or where I can download the image IOS to recover my Router Cisco Model 2511 Serie 2500, or any sol...
| Subject | Author | Posted |
| 11-13-2025 04:57 PM | ||
| 11-09-2025 09:51 PM | ||
| 11-06-2025 06:09 PM | ||
| 10-26-2025 02:24 AM | ||
| 10-24-2025 11:24 AM |
| User | Count |
| 8 | |
| 5 | |
| 4 | |
| 4 | |
| 4 |
