Routing
Labels
Hello,   if I had 2 Data Centers, each connected via BGP to our MPLS WAN carrier network. This MPLS WAN carrier network also contains a number of remote sites also connected via BGP. We’d like to have the two DCs be layer 2 adjacent through the MPLS ...
Resolved! standard acl issue
Hi Team,Can you please help on one acl issue ?I have two devices connected A --- B (ios/ios-xe, issue on both) , having bgp neighbor ship. Device A is advertising 2.2.0.0/16 and 12.12.12.0/24 prefixes to device B using bgp. Device B has route-map app...
Forward by Level 1
  • 172 Views
  • 7 replies
Hello,  We have couple of Cisco ASR-920-4SZ routers, which we are currently using to connect to the Internet. We are planning to upgrade the access speed to 5Gbps which will require us to use one of the 10G ports. We did purchase the appropriate lice...
ZK916 by Level 1
  • 121 Views
  • 2 replies
Hi all!I have a couple of questions regarding ospf route redistribution:1. How can I determine which ospf routers are being redistribute into other protocols? First, I  thought  show ip route would give me the answer, but apparently not. For example,...
rookie R by Level 1
  • 3961 Views
  • 38 replies
Hello all  am not able to see  logs enteries on cisco switch using ssh . Just to understand is there any difference to use Console or SSH to show logging. I have the following configuration on switch . Thanks for tips and tricks     *****************...
uni1389 by Level 1
  • 207 Views
  • 4 replies
