Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2967 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4558 Views
  • 1 replies
  • 16 Helpful votes
Hello, i have a customer that will use this switch model.I was wondering if there is any recommendation from like an AS-BU for the most appropriate software version and what would be ?Appreciate if anyone can contribute to that.Tks,Marcello Ishida
I am unable to connect to webview on our SRW2024 switch. I use a macpro G5 running 10.6.8. When i try to connect to it through Safari, Chrome, or Firefox using 192.168.1.254, I receive a message that a connection cannot be established. 192.168.1.254 ...
Resolved! VLAN ESW-540
Hi,I have a new switch ESW-540 24-port, I upgrade firmware to 2.1.19.I build 2 VLAN for 2 networks: VLAN 2 and VLAN 3 . I don't use the default VLAN 1.This is my configuration:port e1 and e2 : ACCESS PORT on UNTTAGGED VLAN 2port e3 and e4 : ACCESS PO...
I have a Cisco SD2005 5-port switch that broadcasts (destination address: ff-ff-ff-ff-ff-ff) using a source address reserved for IEEE MAC-specific control protocols (01-80-c2-00-00-01) every second. Supposedly this IEEE reserved address is never to b...
I've recently installed an SGE2010 switch, which I have set to 'Layer 3' mode.I have created 2 VLANs using 192.168.10.x and 192.168.20.x (using .50 for the VLAN IP address in each case) - however, I need to be able to allow certain traffic between th...
Resolved! SG 300 Set-up
Hi,I have recently purchased 2 SG 300 switches, 1 x SG 300 52 & 1 x SG 300 10, and I am hoping someone can help me in getting the following set-up working.To assist I have drawn the following simple network diagram (below) which hopefully makes it a ...
Hi All,Over the last 2 months we've had repeated issues with SGE2010 units in a stacking configuration rebooting randomly.Prior to a member reboot occuring we see the following logging message via SNMP Trap on on the unit's internal logging via the G...
c2papacac by Level 1
  • 1453 Views
  • 1 replies
I inherited a network based on the SRW2048's.  I see that they are end of life and warranty support ends June 2012.  It appears that there may be paid support available after this date, though it is unclear. I do not see any firmware updates publishe...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
