Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2814 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4353 Views
  • 1 replies
  • 16 Helpful votes
backuplo                rw       851760      26      30-Aug-2011 10:47:28   directry.prv            --       65520       --      30-Aug-2011 10:46:37   image-1                 rw      7274496    7274496   30-Aug-2011 10:46:37   image-2               ...
Hi ,   I have QOS in my Switch ports and working good base to my LAN VLAN, But when I using wireless My traffic will be goes to Wireless VLAN. in Wireless VLAN there is no QOS. the question Do I need to put QOS config in the Wireless VLAN Interface ?
In section 15, page 336, The 2.3.X Administration guide indicates that the unit will forward multicast packets on a downstream interface only if the device is the multicast querier for that interface. However, the device will not allow a downstream i...
dennypage by Level 1
  • 1133 Views
  • 1 replies
My first question is:  Can a VLAN set up on an SRW2016 v03 be trunked to the same VLAN on an SG300-10 successfully? I have this: RV320 router in very simple gateway mode - no VLANs.  DHCP enabled. { RV320 LAN port} {SRW2016 v03 Port, Access, VLAN100,...
I bought a switch 2918 on eBay for my home lab. However, I noticed that it was not factory reset and has password set on that. I did my self a password recovery. I follow the procedure from start to the end. Then after the password recovery and boot ...
FaSantos by Level 1
  • 1160 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
