Switching
Get 20% off switches when you combine Cisco solutions
Labels
hello I goofed and uploaded a new image to my Cisco 3750.I deleted the prior image and set the boot flash statement and then used the command boot system flash: old image/new image This caused me to enter into switch: mode I have tried various recove...
Greetings!  Let me start by saying I am NOT a network engineer, so I am just now learning how to configure VLANs on switches.What I want to do is to set up two separate VLANs on a SG-200 switch that are totally isolated from each other, replacing two...
I know this has been discussed, but my situation may be more unique. We were having issues with a 24 port POE 3850 not being able to power all necessary cameras (13 I believe). It has two 710w power supplies which is more than enough for this applica...
frankTD4 by Level 1
  • 103 Views
  • 2 replies
I have been task to turn a immature network into something that looks more standardized. I wanted to create a Network Design with Collapse Distro & Core with a single WAN connection and two core/distro switches. Question 1.) For FHRP, what connection...
Mr Cole by Level 1
  • 293 Views
  • 10 replies
  • 1 Helpful votes
 I have a question about HSRP and ACL configuration on Cisco 4506 and 4506E switches.Initially, without HSRP enabled, I configured the following ACL on the VLAN 55 interface:Extended IP access list vlan5510 permit ip any 192.168.104.32 0.0.0.1520 per...
poi05291 by Level 1
  • 122 Views
  • 2 replies
We are in the process of replacing a legacy Juniper Core switch with a 2 stack Cisco 9300 configuration.The VM Hosts within the environment are all configured in the current Vlan 1 on the Juniper switch.We are trunking to these hosts.We have the foll...
KMNRuser by Level 1
  • 338 Views
  • 17 replies
Our IP address on our domain controller has changed.  Do I need to change the IP address in all the configuration on the switches that were associated with that IP address?  For example the command line was -"ip host FQDN 12.12.12.12" and now we have...
glinskim by Level 1
  • 101 Views
  • 2 replies
Hello all, I am trying to get into ROMMON on a C9300 switch. I was attempting to get the switch on our Meraki dashboard and missed a step during the configuration/onboarding and would need to start the process over. I have followed the steps as indic...
Hi! I'm experiencing an issue where all PCs in VLANs 10 and 20 receive the correct IP addresses via DHCP. However, the client (PC4), connected to the same VLAN and switch as the DHCP server, is not getting the correct IP configuration. This problem o...
hello eveybody we have 2 switches where they have same configuration with snmp and access list but still yet they are not working one does work fine and sends alert while the other doesn't send any alert i tried pinging zabbix there is ping without a...
Hello, We need to configure ERSPAN on cisco 3850 and 3650 Switches The source ERSPAN will be C3850: with the below configurationmonitor session 11 type erspan-sourcesource vlan 2140 - 2141destinationerspan-id 100mtu 1500ip address 10.137.200.1    "C3...
