Hi I'm using uc540w-fxo-k9 , I need assistance in opening few ports . When i login to 192.168.10.1 , It will show me command line. Do i need any software ?
Hi, Sorry for my english i have a problem with my SPA514 - if i configure an external ligne, on my rapid link , there is a orange led who flash slowly. The same configuartion on my SPA504 doesn't make this action. any idea ? it is specific on SPA5...
Hi,As i want to implement feature introduced into version 15.1.4(M) at multiple UC520, i want your help to show me from where can i find this release. I didn't find it on download page.RegardsDriss
Hello, I read the article on https://supportforums.cisco.com/document/59936/configuring-sip-proxy-redundancy 1- Is it ideal if I used SPA 502 or its better to avoid this method and use phone with multiplelines like SPA 504? 2- What the limitation s...
Hello, I am using SPA509, SPA514 and SPA525G phones and can't seem to get multicast paging working. I have configured as per the "Document Push-to-talk" and it still doesn't work. Watching with wireshark on the network and I see no multicast; however...
Hi, Is there any way to schedule Do not disturb on the cisco ip phones? or for any model of cisco? the idea is to have it automatically go into DND from 10pm to 8am Monday - Sunday. This is similar to what Iphone offers on its phones. Thanks.
Hi, Is it possible to use a Cisco Unified IP Phone 6901 with an Asterisk based phone system? Thanks, Ollie
I have purchased several new SPA525G2 with Hardware Version 2.1.1 and Firmware 7.5.5a.Once provisioned by the UC320W every 2 minutes the SPA525G2 Refreshes Voice Components. The UC320W is on Firmware 2.3.3(4)The UC320W is attempting to push a firmwar...
Hi,I'm desperately trying to find out the PoE power requirements for the Cisco SPA 514G IP telephone. I've found the data on the 504G but nothing for the 514G. I know it supports IEEE 802.3af but I can't find the specific detail anywhere that will ...
Hi Good day! May I request for technical assistance on the CISCO 7945 IP Phones that are in upgrading status of firmware, but it shows an error and doesn't proceed with upgrading. I tried to do factory settings o...
I've got a customer with a Cisco UC540, they also have a Cisco UC540 on another site, that they VPN onto. They are trying to upload custom on hold music, to the site they VPN onto, in the Cisco Configuration Assistant (CCA), I have seen posts and vid...
I have a SPA504G phone that i have been using then all of a sudden the display screen went blank, the lines that showed green are now off and the following lights have remained on Mute bright red, headset green and speakerphone is also green. Nothin...
Hi everyone, i trying to use a SPA3000 and SPA3102 to make and receive call with PSTN (FXO)It's working fineI have a PSTN Line registered in a SIP serverUser ID: 1001Config a dialplan Dial Plan 1: (<:06732011173>S0) Dial Plan 2: (xx.)And config a VoI...
Is there a way to deregister a SPA302D handset from SPA232D base administration interface? The SPA302D handset was broken and I cannot unregister it from the handset menu.
Hi Everyone, I have a SPA112 and a Iwatsu ix-vta phone. I have SIP all set up and registed, on the SPA112, but the line one status light is constantly flashing. I went here (http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=a3acfa009afd4893ac1257166...
