Hello,When using a SPA-932 attached to an SPA-962, I am trying to figure out how to perform a transfer on an Asterisk PBX. I have tried setting fnc=sd;sub=#700@asterisk-ip on one of the line keys where # is the transfer key and 700 is the extension t...
Hi,I have a little problem with some SPA514G and my UC320W.My configuration is simple, we have a UC320W with a sip trunk to my service provider and we have 6 SPA514G.Everything works fine for internal call and external call trough my SIP provider but...
Hi, I have an adapter which has an odd issue with not being able to answer an incoming call. Outbound is clear quality and working great on both line-1 and line2.SCENARIO: Inbound call comes from provider, phone rings and displays caller-ID. I answer...
I need to set up the prefix '10787' for all outgoing calls and recall numbers, for example, if the custumber dial 0934902738 the system hace to dial 10787934902738 but the '10787' have to be invisible for the customer.I work also with Panasonic's PBX...
Hello,Does anyone know how to specify what goes out on this, the ISP says I cannot forward calls to the outside unless I specify the number. Right now it is sending :504"Redirecting Number i 0x00085, "504Thanks for the help
HiHave a UC540 and a couple of SPA502 & SPA303's which have been setup and are working pretty well. I am trying to add a SPA901 phone and not having much luck. If i set the SPA901 to DHCP it gets an ip on the data vlan not the voice vlan. If I giv...
How to create a post request for a spa 525g2. For spa 504g such a request is valid:http://192.168.2.113/CGI/ExecutePOST /CGI/Execute HTTP/1.1Host: 192.168.2.113Accept: */*Content-Type: text/xml; charset="UTF-8"Content-Length: 92XML=<CiscoIPPhoneExecu...
HiIs it possible to limit access to the SPA504G phone menu? What I mean is not GUI access; I read provisioning documentation and set ua=”na” in xml tags, but it just limited GUI access. Also, I set a password for user, but it limited all phone functi...
Hello,We have a Mitel VoIP system (just IP phones no PBX) in place at our buisness and use 4 analog Polycom Soundstation2s connected to 4 SPA3102s that then connect to a switch (along with the IP phones) then to the Mitel router. Outgoing and incomin...
Hello. I'm From Greece and i have provider Forthnet S.A. I setup the SPA400 first with wizard and with a SPA9000 and SPA303 and i see that i did't have caller ID only Anonymous Caller with Tone Method (European FSK) And with Tone Method (North Americ...
