Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
HiWe're putting in a Cisco UC320W PBX-like box into a small client.They want to power over the network as power-sockets are in short-supply.I'm finding that PoE switches are a bit tricky.Often there are fewer PoE ports than indicated in the specs. On...
rakinonz1 by Beginner
  • 2240 Views
  • 12 replies
I have an AA with an custom script uploaded which plays an audio file when a call comes, then it redirects it to a specific fixed extension. (script made with cisco unity express script editor)I want those steps together, so that it plays the audio f...
Have a client that would like to remove the option for callers to mark their voicemails as urgent.  I know I cannot do this through CCA, but is this even possible?  I am familiar with making custom scripts for AA, but not sure if this is in the same ...
Can anyone help me?I changed the CTI ENABLE setting on my SPA9000 to Enabled, the phones then rebooted but when a call came in to a hunt group it rang for the first call but the 2nd call incommiong to its hunt group it just sat Idle?  I cant work out...
bodgeup by Beginner
  • 2625 Views
  • 2 replies
