Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi ,      I am very new in the voice world, also i configured the SPA942 with CM7  installed on router C2801, they are making calls,  but when i put the  button grPick dont works, the mensage is Call Ended.In my network there are some Cisco phones, m...
Hi,Has anyone had any problem integrating Linksys /Cisco SPA ip phones with CUCM/CUCME?Will the basic suuplementary features work:     - Transfer     - Hold/Unhold with MOH     - Transfer     - ConferenceThanks in advance
loaded SBOM.  Asking for a usename password.I am using username password that works with CCA tool and also allows telnet sessions to UC560.  This user fails.I also used CCA tool to promote user to administrator and this user fails.  Keep getting "Nee...
tknapp by Level 1
  • 830 Views
  • 5 replies
We have a client who wants to have the following setup-UC560 at main siteSR520 & 3 APs at remote site with company & guest WLAN accessWould you recommend a WLAN controller at the remote site with light APs or 3 standalone APs?I have not had an opport...
pro4ianyc by Level 1
  • 686 Views
  • 1 replies
hi,i am currently have 4 scripts already on uc520, and i can't add another one ( it reaches the maximum limit). what is the limitation on the script, and how do i add more scripts when it reaches the maximum limitthank you
TY08 by Level 1
  • 750 Views
  • 6 replies
I just installed 10 SPA525G’s using 802.11 wireless network using the UC540W and AP541.  One of the phones is experience one way choppy calls.  The wireless signal is great and is next to a phone that is not having an issue.  It seems that the callin...
I am installing a UC540 using a One Communications sip trunk. My customer has multiple companies and would like to know which is being called, when answering the phones.  My plan was/is to create line appearances on the phones for each company.  Howe...
jakins12 by Level 1
  • 582 Views
  • 1 replies
We are deploying 5 UC500s - 2 UC560, 3 UC540W in 5 different locations.  Each of these locations will have a direct internet access via the WAN port of the UC500 as well as a MPLS router on the LAN to route traffic destined for the 4 other branches. ...
Hi!I am using freeswitch to connect to my SPA3102 which is registered using TLS.  Quite often I see the following, which results in FreeSwitch ending the call with NORMAL_TEMPORARY_FAILURE.The syslog from the SPA3102 looks like this:Mar 19 19:58:15 x...
