How do I setup voicemail access for employees that are out of the office? They want to be able to dial in and get there VM. We're using analog lines.Thanks in advance~
Hi,I have set up a vpn through CCA that uses a pre-shared key and it works great. I was just wondering if the UC520 can handle a certificate instead? If so, are there any instructions on how to do it? Also, I know that CME doesn't have much support f...
Hi again!!When i call the spa400 take the call you dial the ext. and the call cuts off!!I reset the full system, i reconfigure it with wizard 2.1.0.0 and still the same problem.so any ideas?Best regards.
Hello,I work for a Cisco disti and one of my customers installed a unit of SPA8000 at a taxi station.Because of the background noises at the station, they rely on analog phones with a ringer led.The phones that they are using are:HYUNDAI HDT-1602http...
Hi,I´ve got a customer that want´s to use the new SPA5xx phones on an Asterisk PBX.We are looking on the possibilities on making these phones as a default phone on our Asterisk deployments. We are hoping that there is a open source project on remote ...
Hello,I guess it's a newbie question, but I really read all the documentation and couldn't find a solution to my problem : when I get an incoming call on line1 I would like to be able to pick it up on line2 or on line1, but dont' know how to have bot...
I am having trouble getting outbound calls to work, the call begins with a fair amount of feedback, is fuzzy and the volume is so low you cant really hear anything? The device is located in NA and it receives PSTN calls perfectly and forwards those o...
We have 7911s, a 7931, a 7936, a 7921 wireless and some 7940s connected to a UC540 running IOS 12.4.How can I make the name at the top show "first name" first? If it's not possible for all of these models that's fine.
We have a couple ESW switches in a UC540 deployment. One of the servers on the switch has VMs. we are noticing that if we share a NIC between any two VM or between the host and a VM we lose connectivity. I am assuming this is port security on the ESW...
Has anyone seen this before. I'm trying to install an 8 user license on a uc540. Attatched is a show flash allUC540#license install flash:FHK135070B7_20100108094117972.licInstalling licenses from "flash:FHK135070B7_20100108094117972.lic"% Error: Li...
Wanted to provide some feedback on what I am seeing with CCA 2.2.1 and UC520 16 user:I'm running into some consistency issues when configuring monitoring and intercom extensions using the Configure tab, Voice section, User Extensions tab. If I go th...
tengo configurado un spa3102 y un servidor Asteriks.Las llamadas que salen del Servidor hacia el exterior funciona (VoIP-PSTN)Pero cuando resivo una llamada del exterior el SPA3102 suena y corta, suena y corta (Ring y corta) y nunca entra la llamada ...
HelloIn incoming dialplan I have no display of did numbers which have been set up. I know there there cus they work but nothing in the displayHas anyone come accros this beforeAndrew
I have a client that needs the 'missed call' message to stay visible on the phone until the handset is picked up. I tested it here on my system with the latest software pack and the '1 missed call' message stays on the screen until I do something to ...
