HiI have a problem in BLF in SPA 504G , i checked all the configuration as this link https://www.myciscocommunity.com/thread/8186?tstart=0 , but it didn't help .the IP phone software version is 7.4.3please advise.ThanksNisreen
Hi,I have a customer who has three sites , I'm going to implement a UC520 system in each site, the connectivity between the branches are there over VPN tunnels. my questions are:can you provide a document for the configuration of the UC520 in multibl...
I am not a CLI champion, but I need to have a translation rule to when my customer dials for example "86600" it would dial 800-555-1212. Could someone lend some help on the process that I would need to do please. Thanks Any CLI help would be appricti...
I am having an issue with my bACD on a UC520. I have 5 receptionists in a hunt group BACD. Their phones display when a caller is in the Que which is good. The problem this has caused is that if they park someone while it is displaying that a caller i...
Hi,Need some help on this one:I have a setup consisting of a SPA9000, SPA400 and SPA942 phones.Typical use upon leaving the office is for each user to do a CFWD to their cellphone.This works well, except the volume is very low - both the caller and t...
Hello,I have a customer who already ordered the following circuits and is now asking if a UC500 can accommodate them.1 x Voice PRI, 1 x Data T1 w/ managed router (Internet), 1 x point to point T1 to remote site (with identical UC500 system)The UC500 ...
Hi everyone,I have two questions they are as follows:1* I have setup voicemail on extension 206 and it works fine but the LED light on the handset dosn't come on. I have looked in the CCA and even in GUE but cant see anything to active the LED.2* Whe...
I wonder if any one has experience on tuning input gaina dn out put attenuation on the gate way ...We have a customer is experiencing the voice volume low issue. They have a 2801 vocie gateway run MGCP to cucm and using FXO/FXS for outgoing and inco...
Hi Everyone,I have a customer with a UC 520 telephone sytem. The equipment has been setup with 2 ISDN ports. At this stage only one is been used, but everytime I do work on this, it actives the second ISDN port. The first call pick up 0/1/0 port. Whe...
Hello,I'm attempting to download the Office Manager Beta and keep running into issues. I'm asked for a username and password (such as that required for ftp) after accepting the license agreement, even though I am logged in as a registered user. Can a...
Hi,I have a SPA2102 which had problems after the firmware upload.The LED's of the ATA are blinking SOS after powering up.When I connect the "Internet" Ethernet port of the SPA2102 to my switch, I can ping the ATA.Is there a way to recover my SPA2102...
I've got a UC520 connected to an ESW540, which is then connected to another ESW540 in another building by a fibre link. The fibre link is run through two 3Com Surestack switches (old), while we wait for new fibre cables to link the ESWs directly.Usin...
Hi,I try to setup an ATA to use my analog FAX machine over VoIP.Situation: Brother 7225N FAX machine, PAP2T oder SPA 2101, Ethernet, 3CX PBX - software, Patton 4552 Gateway to ISDN public network.Result: Phone works, FAX receiving works with SPA 210...
Hello all,I need help with configuration between internal extensionrouter wrt54gs tomato, switch bsfr41spa9000 v2 (and V1) DMZpap2t (analogic phone), rt31p2 (analogic phone)and 2 ip phones swissvoice ip10s.all in the same networkall the phones can di...
We have this box on the outside of our building that is an entry phone. Basically it is a box with a button and a speaker. I connected it to a FXS port. When you press the button, it gets dial tone. It is extension 301. Is there any way to prog...
