Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I just purchased a WRVS4400N with the intention of giving myself a secure way to remotely access my local network from anywhere via VPN. I created a local VPN account and had a friend install the QuickVPN client on his system. He gets connected (I ca...
If WPA-PSK TKIP or AES encryption is enabled, my Spectec SDW-821 SDIO wlan card can not connect to the WAP4410N (h/w "WAP4410N-E V02", f/w 2.0.2.1). If security is off or set to WEP 128 bits (thanks to Cisco's support), connection succeedsThe card wo...
Hi ! I bought a new WAP4410n a few weeks ago. Since then, I had tried different ways of configutarion to make that WAP4410n works as a repeater to my WRVS4400n v2. Both are running the lastest firmware available by cisco. I made the WAP4410n a mirror...
Recently bought a 892W security router.In setting up it I get the empty screen with only an enter button (offceextend ap)Now I saw a solution to this problem for the 891W somewhere in these pages however I can not download the appropriate software si...
hi,i set up the WAP4410N and it can be connected with our router. But it's not protected by our password, but once i have set the password of WAP4410N by changing the security mode to WEP, now i will prompted to password when I connect the AP, but it...
Hi,Recently I have purchased two brand new wap4410n access points. I have connected my computer directly to one of the access points, and attempted to connect to the Web Configuration utility through my web browser.I'm using a: 09' MacBook Pro, runni...
Hello,I just purchased the Cisco Small Business Wireless-N Gigabit Security Router with VPN (WRVS4400N). I'm moving overseas (to Israel) and noticed that the power supply does not go up to 240V. I then called the Cisco Customer Support and they told ...
as the subject .. All those who have the WAP4410N ...want the new firmware 2.0.4.1 and solve the AP problems of stops an repeat. believe in CISCO.https://supportforums.cisco.com/message/3292474#3292474https://supportforums.cisco.com/message/3285679#...
Hi I need a power Injector compatible for WAP 4410NSomebody can help me pleaseThanks
I've been using the SA520W for a few months now and just yesterday had shipped in an AP541N. Expecting that the device would share a common interface, I wasn't disappointed. However once I got into the menus a bit more, I began to see that in many ...
How to import certificate for eap-tls to WET200? There is a message like this "unsupported format, only PKCS#12 is supported". I have Personal Information Exhange certificate file (.p12) - it should be PKCS#12. Where is s problem?
Hi everybody, I'm a french cisco solutions user since three month and I've got problem with one IP phone (cisco 7921). I can't find informatrion in France relative to my problem so I leave a message in this forum.I explain: One of my 7921 phones disc...
Hi.I have a customer with a linux OS machine running Cisco Wireless Controll System.He needs are to add a new wireless AP with the following features :- compatible with most laptops- exterior conditions "resistant" (sun, rain...)- reasonnable perform...
Dear Sir/Madam,We are one of the on growing local Internet Service Provider (ISP); we recently planned to expand our SME into Wireless Internet Service Provider (WISP) with establishing wide range system technology within our community.As we have men...
Where can I download the user manaul for this switch, not the quick start guide?Thanks
