Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
We have an existing Citrix Security Gateway and Web Interface that works fine within our wired network and is accessible via internet connections outside of the office -- all of our Citrix apps are accessible. We recently installed a Cisco 2100 wire...
We are experiencing issues when we flashed from 2.0.2.1 firmware on our Cisco Small Business WAP4410n to the recently released 2.0.4.2. This is a brand new unit that we received. After flashing from 2.0.2.1, if the SSID Broadcast is set to "Disabled"...
Looking for a Cisco, low-cost power injector solution to push the WAP4410N. Network is all cat6 and the AP is 100ft away...Thanks, MarkI'm long on Cisco - I believe in the future...
A couple of questions about the AP541N:1. Does anyone finally have these installed and working properly, especially in a clustered environment? I have read so many comments about slow performance, no performace, bad coverage, etc... They sound like...
HiI just got 3 AP541, the reason for getting this was the dualband...but has anyone gotten this AP to actually give both 2.4 and 5 GHZ at the same time???I have in my other office a Asus RT56, it costs about 1/3 of the cisco and this supports both 5 ...
I just recently replaced an older linksys pre-N router with a RV 120W. I thought this would be a good choice as a more professional router. I installed this router last week and things seemed to be working normally for web browsing, though I was re...
Hi:I recently adquired an AP541N Version AP541N-K9-1.7(2) and found that it has telnet and ssh ports open and cannot find a way to block access through this ports.SSH and TELNET console are linux, it looks like a customized linux distro. I dont like ...
Need to boost signal coverage on an SA520W (even though it is very good, building floor is too clutterd and too darn big.Even using a 2nd unit to extend things may not get it all done; However, searching the site tells me there is an external aerial ...
Apologies if I overlooked this somewhere..But I want to extend the wireless coverage in a clients office.1st SA520 is in a Rack at back of premise.Want to provide a couple of 7925 IP phones for use by staff.Even with the excellent coverage a 520 usua...
I have a office that was converted from a older townhouse. The building has 3 floors with the distant of each floor expands no more than about 60 - 75 feet from end to end of the building. Not sure what's in the walls as the building is at least 20...
I have a cluster of AP54 IN. When guests try to access guest network, it should prompt with a webpage for a login name and password.Any clue?Many thanks.
Hello,I have a big house and I had bought the equipments:Router netgear3 Access Points - wap4400nSomeone They told me that I could use the same network name as follows:2nd floor,set the Access Point (default)On the first and third floor set the Acces...
I have seen posts and screen shots of WRVS4400N settings screens showing WDS but I can't find anywhere in my setup to enable WDS on my version 1. I am running firmware 1.1.13. This makes me think WDS is only supported on v2 of the WRVS4400N, is that ...
Hi,I have recently tried to install three 4410N's...one as an AP with the box ticked that says "Allow wireless signal to be repeated" and the other two as "Wireless Client Repeaters" with the "allow wireless station to associate" box ticked. I've als...
Our wireless clients that connect through our AP541N cannot see other computers on the network. They can ping other computers by IP and host name and access the internet OK. Mapped network drives can be connected initially but are very unreliable a...
