Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have 3 unit WAP321 was faulty on the Power, just no led and no power, but after on for a moment you will feel heat for wap321, i have request for claim warranty ,after 3 week the replacement unit delivered , and i try to setup its fine , after the ...
Hi, I have a number of Cisco WAP 581's in a Cluster all running 1.0.2.0 and noticed that 1.0.3.1 had recently been released (22nd April). I upgraded one of my AP's and noticed that it still reported the software version as 1.0.2.0; looking at the MD...
Join us for a demonstration on the management capabilities within the Cisco Business Wireless product line for small businesses. For the lone-IT-superman, it is critical that the network products are easy to buy, intuitive to deploy and manage; as we...
I recently bought a second WAP371 in order to extend the range in my house. To the best of my knowlege, I've configured both AP's according to: https://www.cisco.com/c/en/us/support/docs/smb/wireless/cisco-small-business-300-series-wireless-access-po...
Hi guys,Im in the UK and i am currently running two wap571's all fed at the moment via a EdgeRouter 12We have Sky TV, and on my iphone8 & I use the Sky Go app which allows me to see a tv guide and also what recordings i have to watch.Over the last co...
Hi,I've got 5 Cisco WAP 581 access points connected with the cluster.Firmware version: Active Firmware Version:1.0.1.5The problem is with Internet conectivity. User can connect to wirelless network SSID which is working on 5ghz and 2.4ghz with the sa...
So need some assistance....WAP371 with two ssid's: public and private....private vlan1 and public vlan 2....wap371 connected to netgear switch with tagged vlan enable...netgear plugged into asa5506...asa5506 configured to accept both vlans...with pub...
Hi All, So i just enrolled into CCNA and a mate gave me a 2960G switch and a 2611xm router.I am practicing at home and have the cisco router connected to my home modem.I have successfully created vlan 10, where all my home devices are connected to th...
I recently changed my router’s IP addressing scheme from 192.168.x.x/24 to 10.101.x.x/16 (it’s an air-gapped network for lighting control) and now I can not find my WAP371 on the network. I know the default address for the WAP is 192.168.1.245 and ha...
Hi, I have the WAP571 and when I set the LAN as static IP and I assign the IP the wireless provides the IP169.254.101.242 and no gateway or DNS. Thanks
The WAP581-A-K9 V01 (Firmware 1.0.0.7) access point is slow moving data across the LAN and cannot figure out why.
Have perfect wifi speed but slow moving data. Using IPv4, not using IPv6 (no option to disable in GUI)
VLANS are TAGGED. Does not give a...
I need to know which Wireless AP is best to use to extend the LAN between two buildings. The last devices I used for this were 1310s. I only need to bridge the building so no client connections. Also need to use external antennas on both sides. Secur...
Hi, I own a WAP150 I purchased in Amazon. It never worked well. Today I did a network analysis using some tools in my Mac and the report indicates my AP is in DE country (Germany) while all the other neighbours are in the ES country and this might be...
