Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,i have a customer of mine that uses just 1 WAP 371 for a whole floor of users. max devices connected: 21Sadly, this happens a lot:after a few days of working normally, the users all get constantly booted of the wifi.only thing i can find is thi...
All, Recently purchased a WAP581 (arrived with firmware 1.0.2.0) - which oddly enough is NOT available via Cisco's downloads??? That aside, was trying to get the Guest Portal running, however the WAP doesn't appear to be redirecting the client proper...
Hi,I have 5 wireless access points WAP581 (Firmware Version: V1.0.2.0)All these devices aggregated to one SinglePoint cluster.My problem is that the devices reboot themselves randomly. I have noticed following Syslog entries when it happens: Feb 22 2...
I'm looking to design and set up a network that can handle up to 1000 simultanious connections, mostly wireless. I've done SOHO networks before with one server but nothing of this size.network, server, wireless, Requirements are:Application ServerD...
Someone may have to wait and answer this in late March after the CBW240AC ships. We're moving from Cambium Networks equipment to Cisco equipment in March. We'll be using the Cisco RV345 for the router, and a Cisco CBW240AC for the WAP. On the RV345, ...
HelloI searched in internet and Cisco site but unfortunately, i couldnt find anything.I want Azimuth and Elevation Radiation Patterns For WAP371.best regard.
I am needing to replace my WAP. Cisco Small Business recommended either a WAP125 or WAP581. The WAP would be installed in my office at one end of the building, and I’d need coverage throughout the entire building. I would need at least 1730 Square Fe...
We have a building that has been expanded several times. The latest addition increased the WAP371 count to 19, exceeding the 16 AP max per cluster. Is there a way to configure 2 clusters so that a mobile device can move from an AP in one cluster to a...
Hallo Cisco Community, I need help once again. As I said in the Title, only VLAN1 has access to internet.I created DHCP network pool for the WAP which hangs on Port 6. On port 6 there is also VLAN 160 which is supposed to serve for mobile devices an...
Hi everyone We have a few WAP150's hanging around, and to fix the issue of the gateway not being used proparly we're upgrading the firmware, carefully. An issue came up: we use 2 NPS's as radius servers for 2 different networks. One network (VAP1) us...
Hello Experts,Issue - Users not getting IP only on 1 SSID for particular period of time. Time is fix. Not specific to Peak hours. SSID Details - Guest SSID - Corp.guestAuthentication Type - 1st PSK (Locally configured on WLC) then 2nd Web Auth (on RA...
Hi All, We have multiple sites and have started to purchased WAP 150's instead of the 321's. We have used 321's for a long time and were great. The 150's are very similar and so we have now been setting those up. On two sites our 150's have been lo...
Hallo,I have a switch SG350 with its basic configuration, I am still building my network. In the meantime I got WAP571 which is directly connected to the switch. I did initial configuration and I can connect to access point but there is NO INTERNET A...
Hello,My english is not very good, but I will try.I have a WAP121 Wireless-N Access Point with PoE and I have reset it by mistake. Therefore I only have a wifi signal in half of our house. As far as I can see, I have to configure it all again, but in...
Hi, Currently, i have Cisco 877w with IOS flash:c870-advsecurityk9-mz.124-4.T7.bin, I need to upgrade IOS c870-advsecurityk9-mz.124-15.T6.bin or newer version. I cannot download from cisco website because end of life & support. I have contacted Cis...
