Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 589 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2835 Views
  • 1 replies
  • 5 Helpful votes
I seem to have an issue with QoS on a stand-alone configured WAP361 AP. With WMM enabled, the client connected to the AP shows a data rate of 866Mbps on the Monitor/Clients page but actual TCP download speeds for some reason do not exceed 1Mbps. When...
Johan166 by Level 1
  • 750 Views
  • 0 replies
Resolved! WAP 4400N
HelloI have more than 10 WAP 4400N the problems I meet the most1-the wifi signal is good but no one can connect this AP refuses any connection saying that the « password is incorrect » when I disconnect the ethernet cable (POE) and I connect after a ...
Y@n94 by Level 1
  • 1064 Views
  • 2 replies
Hello everyone, After a whole lot of testing (years of work!), I think I have finally figured out the best configuration for WAP series. By default they have some problems with Apple devices disconnecting every couple of minutes, with Airplay and so ...
Hi All, We have two WAP 150s. I updated one to the latest firmware with no issues when I attempted to update the second it appears that the update was bad. The LED blinks green and reboots every 30 seconds. I was upgrading from firmware version 1.1.0...
