Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
i have issue with my AP 1602i SAP i wanna to configure server dhcp to allow ip addresses dynamically so can any one told me if it's possible to make my access point as server dhcp for the client dhcp
Any idea on this? it keeps doing this over and over.Jun 3 2014 14:29:07errmDNSResponderERROR: getOptRdata - unknown opt 65002 Jun 3 2014 14:29:07errmDNSResponderERROR: getOptRdata - unknown opt 65002 Jun 3 2014 14:29:06errmDNSResponderERROR: getOptR...
I have two WAP4410N. One of he accesspoints is connected to our wired LAN, called by now AP1. The other accesspoint is connected to the first accesspoint by WDS (Client mode) called now by AP2. I have upgraded both accesspoints to firmware 2.0.4.2. B...
We do have 4 (four) Cisco WAP321 in one of our offices. Things were working pretty well for a while. Then clients are randomly being disconnected from the AP (Windows laptops, iOS and Android phones and tablets, etc). Looking through the logs, I not...
Hi GuysWe have 3 WAP321 units in the office, and while most of the time they work ok, we have had some issues where by users cannot connect. I have searched the forums already and found a related issue (the answer appeared to be to turn off TKIP and ...
Hello everyone. We have 18 AP541-Ns and 2 WAP551s at our office. And we want to use them by cluster. My question is that, can these Access points support each other? If someone have any idea on that, please assist us. And another one question:They ca...
we have 6 WAP4410N-E V02 devices working, but periodically they stop working and after reboot they work again, maybe because there isn't traffic?.Last firmware installed (2.7.0.4). Any workaround to solve it?configuration?
Hi guysI have a WAP121 AP, and i want to be able to setup a guest SSID along with my full access SSID. The guest network should only be able to access the internet.I have the AP plugged into a single port on a Netgear GS728TP smart switch.I know i ha...
Hello, I have two access point WAP561 with the last firmware ( 1.0.4.4). I have big trouble with apple Imac & Macbook.-Apple disconnecting-Bonjour Discover didn't work after 2 daysI must reboot every 2 days the AP for workaround the problem. I had tr...
WAP551 and Apple Macbooks - connections drop every 10 minutes. The Apple Macbooks are from 2007 till 2013. WAR551 are up to date and in cluster mode (3 WAPs).Here is a LOG from an Apple Terminal:>> associated to "YETU". Bailing on auto-join.>> Thu Ap...
I need to setup a wifi hotspot for my customers at my café. The size of the café is about 100 sq metres, and max number of users is 100, though it is likely to be around 50 on normal days.Is a single WAP561 access point sufficient for my usage, or sh...
I have 1 WAP321 for guest access.Now I need to isolate traffic of guest captive portal from my LAN.How can I do this?Thanks in advance.Sorry for my english
Hi Team, Working for the one of the Hotel project where we have considered WAP121 AP's for the wireless coverage part. WAP supports only single band. Now in a days their are dual band WiFi clients (iPhones, Anroide base smart phones -which supports d...
As the title says - I have a wap4410n acting as AP and a second wap4410n acting as wds repeater.I've only managed to get the wds repeater to work when it has a different ssid to that of the ap - I'd like the wds repeater to have the same ssid as the ...
