IP Telephony and Phones
Labels
I configured a FXO trunk port to a Valcom 9964 feedback eliminator. When I dial the route pattern associated with the FXO port on the Gateway there is about a second delay then I recieve a fast busy tone. If I sh call active voice compact I see the f...
wrickk_2 by Level 1
  • 459 Views
  • 1 replies
Hello,I have a question about some voip/vpn configuration. I've got two sites that have 1760 routers with fxo/fxs cards that are going to be tieing the two phone systems together with a couple of voip trunks. These are secondary devices on the networ...
Guys,I have an upcoming upgrade for a customer from 5.1(3) to 6.1(2) and then soon onto 6.1(3).We have everything ready to go, except the customer is worried about the need to re-login all EM profiles. We have a LOT of phones.Is this going to affect ...
cjhunt by Level 1
  • 1135 Views
  • 8 replies
Hello,We have three H323 gateways configured in CUCM 6.1.2. The 1st and 2nd one are GSM gateways and the 3rd one is the Cisco voice router, 2821 with 1 E1 line. The problem we are encountering is that when the 1st GSM gateway is busy, calls are not h...
cg100668 by Level 1
  • 607 Views
  • 2 replies
guys can someone please explain the difference between these protocols i am a new bee to iptel.....whats is the main diff and what is the purpose that we will select h.323 over mgcp or sip.....thanks guys in advance
Hi, we are experiencing an issue in Dubai.Could it be possible that a provider doesn't send the "Type of Number"? (e.g. National or International). If they are not sending this information, can i adjust the setting / command for "progress_ind"? Witho...
