Dear all,I want to know if any tools can be bulk insert route pattern and Route List in CCM?regards
Does CME act as a normal CCM? or do we need to manually make dial peer, and destination patterns on the gateway router connected to the CCM pointing those numbers to the corresponding phone IPs off of the CME router? I'm not great with voice but co...
I am having an issue with a new carrier for 3 digital PRI lines. I am attempted to determine if it?s a carrier issue.The equipment we have:1) Cat 6500 Core2) 6808 module connected to it for the digital t1The new carrier sent us 3 PRI?s with one trunk...
Hello,We have CallManager3.3(3) and will install Cisco28xx for PRI-E1(G.703).Is VWIC2-xMFT-G703 necessary ?We have no experience of G.703. Please teach me.regards
I have a Sip connection between a Cisco 2811 and a AudioCodes (Carrius) system. Call can be completed in both directions without any issues. Our issue is faxing. A fax will complete fine if the recieving fax is not set for "auto receive". From what I...
Dear All,We have a global customer who what to know what ware the advantages/disadvantages or benefits of MGCP, H323 and SIP. baysicaly when is recommended to use one over the other one?I guess that the IP Networkers with lots of real world experien...
Hi to All I'm running a Call Manager 4.01 in Paris with a H.225 Trunk (Gatekeeper Controlled) over the WAN to a gatekeeper.Also have a Cisco 2600 router, registered as Gateway with the same gatekeeper in Scotland. The Cisco 2600 router has a E1 circu...
I'm working on a client AVVID and they don't have the DC directory manager password. I see the encrypted version in the .ini file. How can one recover this?Thanks! CCM version 4.0
HiI have a callmanager in my lab that has loads of previous config in it, does anybody know a quick way to return the database back to day 1, ie no user config. Without re installation.
We already knew overlaid ephone-dns can be configured for an ephone button in CME. For example:button 1:21 2o22,23,24 3:25Here button2 has three numbers 22,23,24.Is it possible to configure multiple directory numbers per line with CallManager?The cus...
Hidoes anybody know how you can reset or find the following passwords for callmanager. I have a client asking for this information and we only have the admin password for the system.DC directorySQL sa passwordCan these be reset if lost without comple...
I was wondering how many people are using the default wav files for Music on Hold or are you using a custom wav? If so, is it music or is it announcements
I?m using headset plantronics 400(dsp) usb and ip comunicator 2.0.1.1 and when a calling to ip phone (hard phone) or analog or whatever, in the ip comunicator hear fine but the hard phone hears noise (like electrical noise) after the ip comunincator...
Hi, I'm setting up an intercom system, where a phone is set up at a locked door. A Line group is also set up so that whena user piks up the handset, the phones that are in the line group will ring, so that someone will open the door. The only rpob...
All,Are there any best practices for DHCP for your devices on a data or voice VLAN.i.e.If I have data vlan of say, 10.10.10.0 /24 and I have a voice vlan of 10.10.11.0 /24would it not be nice for troublshooting and design purposes to have the host p...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
