IP Telephony and Phones
Labels
No issue. Just an FYI for all of you.I just setup RTMT v15 and found that there was no installer. Just a program folder called CiscoRTMTPlugin with a run.bat file instead of an executable. I copied the program folder to c:\program files\cisco\ . Then...
Hi, all What is the option in the cnf.xml file, that disables sdp-anat for CP-9971. Our case is calls between Asterisk and CP-9971. That calls from 9971 to Asterisk ends with SIP 420 'unsupported required extension: required: unsupported:sdp-anat'. A...
ren fau by Level 1
  • 773 Views
  • 1 replies
