Routing
“Webinar
Labels
Hi,we are using the Cisco ASR1001-X as core router on our ISP network. For the management of the CPE I set up a TR-069 ACS server. For testing purposes I configured the ACS URL manually on the CPE, which works fine.However I'd like our ASR to pass th...
andy89 by Level 1
  • 301 Views
  • 10 replies
  • 1 Helpful votes
Hi,   I have a scenario were i have to implement a solution which allows for dual ISP redundancy on spoke into dual hubs in a dmvpn environment.   I have created two tunnel interfaces, both have tunnel source set at each respective physical interface...
eirikalim by Level 1
  • 880 Views
  • 4 replies
Hello Guys,We are planning to upgrade Cisco router Cisco C8300-1N1S-4T2X from XE image 17.6.5 (Rommon image 17.3(5r)) to latest XE image 17.9.5a. As per Rommon compatibility matrix, this new XE image should have minimum rommon image of 17.3(1r) and m...
Noovi by Level 1
  • 77 Views
  • 3 replies
Hi, I am setting up smart licensing on several L2 and one L3 switch. L2 is working fine, L3 not. It seem that fqdn's can't be resolved.On L3 dns server is set up. There is a transit VLAN between L3 and the firewall. When I specify the source in ping ...
mcgiga by Level 1
  • 117 Views
  • 4 replies
 BST: %IOSXE-2-PLATFORM: R0/0: kernel: EXT2-fs error (device sda1): ext2_lookup: deleted inode referenced: 3170306  BST: %IOSXE-2-PLATFORM: R0/0: kernel: EXT2-fs error (device sda1): ext2_lookup: deleted inode referenced: 3170329  BST: %IOSXE-2-PLATF...
DearsIn our environment we had configured UDP IP SLA probe which gives us the desired results to monitor IP SLA statistics from Source to Destination. But the negative part is, this probe does not tell us in which network hop the latency occurs.I had...
rhari by Level 1
  • 68 Views
  • 1 replies
Hi, I have a ISR1100 (C1111) with two connections: fiber (GiE0/0/0) and LTE (Cellular0/2/0). Config excerpt:ip route 0.0.0.0 0.0.0.0 100.64.107.1 name primary track 1ip route 0.0.0.0 0.0.0.0 Cellular0/2/0 10 name backup!ip sla 1icmp-echo 8.8.8.8 sour...
Sakura by Level 1
  • 922 Views
  • 19 replies
Thank you for your help.There is no power button on the Catalyst9000 switch, but is it okay to pull the power cable out of the switch when it stops?In the case of a ISR4000 router, a soft shutdown is required by the reload command in advance, but I w...
Translator by Community Manager
  • 89 Views
  • 1 replies
