Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I got some new networking equipment today and after some frustrating hours trying to get my new router and bridge to work I am close to give up.1. I have bought a RV220W router this will be connected to Internett and all wireless devices will connect...
Hi, Can any one help me on above. I need to configure WAP4410N wireless access point for our company guest and visitors.i need them to only surf internet and not to go to LAN (servers).I think i need to create VLAN for this ? can any one tell me sett...
Installed 4 AP541N units in a client site and they've now come back with reports of issues with the setup. I went out there today to take a look and the issue is primarily that randomly during the day, clients will loose access to DHCP. The client ...
hello.So trying to help out a family friend set up a small business network. They want to have a private wireless network and then a smaller network for guests and some employees. So I read https://supportforums.cisco.com/message/3344651#3344651 and ...
Hello!We have Cisco WAP4410N-G5 with firmware 2.0.4.2 and two notebooks with 802.11n adapters (Intel Centrino N130 and Ralink RT3090).Network scheme: Server 1Gbit LAN <> Gigabit switch <> WAP4410N <> notebooks. On server we have samba, http and FTP.W...
Hello,I have a few questions about the Cisco WAP2000 we setup for our customers that I have experienced as of late.1. The AP is prone to reset automatically; what causes the access point to do this and how can this be prevented?2. The AP has the SSID...
Over the past 12 months I've purchased the following products from the Cisco Small Business range;1 x Cisco WIP310 Wireless-G IP Phone3 x Cisco WAP4410N Wireless Access Points2 x Cisco VC220 Dome network cameras1 x Cisco VC240 Bullet network cameraTh...
First: I am no communications expert!I am using a Netgear Wireless-N Dual Band USB on my windows 7 ultimate PC, Cisco WAP200, Netgear N600 ADSL2+ modem router. All is well except for the WAP200.I just installed it and updated the firmware (Using WAP2...
Hello,We have our Wireless network that loosing connection after 2 or 3 days of a normal functionning, we have to restart the APs each time.The configuration is for about 100 users and seams for me to be simple and usual as for this cases :router and...
Hi Everyone,I currently have a WAP4410N connected to an ethernet switch and the signal is very weak when attempting to connect to the AP from 4 rooms away. The structure is all block and the signal does not do well between the solid walls. I would l...
HiPID VID:WAP4410N-E V02Software Version:2.0.1.0Local MAC Address:C8:9C:1D:27:19:4AHello i have two WAP4410N wireless router. with software version (2.0.1.0) , here i have a problem on SSID broadcast and access .. i have created Two ssid's WC72 and S...
Help on the config. WAP4410NWAP4410N Help on to configureHI Guys,I have 2 Wireless Access Points WAP4410N. Iam very new in Using these Wireless ACCESS points. initial configuration I have done with the help of Starting guide. Here i want to know few...
We've had this AP for just over a year and just recently it started dropping its wireless connection. To fix, I have to and unplug the power and then plug it back in.. Then it works again for a few hours and drops out again. If I navigate to the con...
I'm trying to configure a Cisco Small Business Router - WRV210 for WPA2-Enterprise wireless security. I'm currently having trouble getting Radius Authentication to work.Our Radius Server (10.1.0.1) is in our corporate DataCenter. I've successfully co...
Hi teamWe have 3 WAP 200 installed at our office, and i was checking the speed yesterday i been to www.speedtest.net, and we have cable modem, the speed i was getting 25.0 Mbps down and 2.0 Mbps UP when i was connected via a wire, but if i am connect...
