Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2681 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7317 Views
  • 4 replies
  • 17 Helpful votes
We have 2(two) SG300-28 switches. We have several VLANS that need to be truked between switch A and switch B 1. We are able to create 1 TRUNK port  that includs vlan 2,3,4 and it works fine between switch A and B.  We are now trying to create a 2nd T...
soupensu by Level 1
  • 433 Views
  • 0 replies
Hi guys, So here's the setup: 2 switches: Switch1 3560x Switch2 3560x (10gbe c3kx-nm-10g module) 3 vlans: 1(default) 200 (storage) 201 (vmotion) poweredge servers: a blade m1000e chassis with 10gbe pass through module esxi for ose on the blades. ...
cposenjak by Level 1
  • 663 Views
  • 0 replies
Anyone have an opinion on this?Setup:An sg300-10 configured in L3 mode.There are 4 vlans defined (with 4 IPv4 addresses, though the sg300 is not routing -- other device does).In IPv4 all works fine.Trying to add IPv6 to my network I found out that:- ...
n.sinanis by Level 1
  • 6910 Views
  • 12 replies
I have a couple of SG300 28 port switches that I just purchased over the last few months, we changed out our phone system so we using voice over IP phones and the phones are now connected to our pc's.  For some reason, the ports are dropping on the s...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
