Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2812 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4353 Views
  • 1 replies
  • 16 Helpful votes
Hi,I will like to set auto baud for the SG500. By default its 115200bps.I had tried the following methods:1) switch xxxxx (config)# line console    switch xxxxx (config-line)# autobaud  --------------------> my terminal hangs and print out rubbish2) ...
reginachh by Level 1
  • 4243 Views
  • 1 replies
Resolved! POE Switch
Is the SF100D-08P unmanaged POE switch a discontinued model? If so, is there a comparable replacement? I'm looking for a reasonably priced switch to power WAP access points.Sent from Cisco Technical Support iPad App
                   I need a little guidance. Trying to connect SG500X-24 switches to a new installation of MOE (four sites)provided by Century Link.  Anyone have any experience with this?  I have tagged the uplink port with the MOE vlan, but traffic ...
I am trying to get QoS for my VoIP system setup on several SGE2000p switches and have got a question...How do I define the ACL for RTP? As far as I can tell it will not let me enter a UDP port range for the RTP traffic... And I cant imagine creating ...
Please send me the best propose for the following specification :Switch will be used for CCTV system for up to 20 Cameras.•1)      10/100 BaseT Fast Ethernet Ports ( at least 14 ports )•2)      10 /100/1000 BaseT Gigabit Ethernet Ports ( at least 12 ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
