Hi,Has anyone created an XML app that is able to monitor a call parking lot in Asterisk (quite possibly using the AMI interface)?Many thanksSean
Hello, how can I recover the phone? What I have tried is the software in this discussion: https://supportforums.cisco.com/discussion/10616406/spa962-sos-recovery-mode but it didn't work. The software didn't find the phone. What I need in the compu...
Hi I am having a problem with a UC 540 where there is only one way audio. Initially I was having it with outgoing SIP calls which I am still troubleshooting but as a temporary solution I had made all outgoing calls via PSTN. This had the same result,...
I have an php script which generates an xml corporate directory. On SPA 525G everything is working fine, but on 303 and 502 i get an error.Looks like my script is correct, becuse I have same problem with example provided here. e.g this oneAll firmwar...
For the purpose of debugging of secure provisioning I need to have a SPA508G with the "factory default" firmware, e.g. 7.4.3. So I got the one (with current 7.5.6 firmware) and downgraded it.The downgrade itself has been successful, but the phone don...
Connection straight from the wall jack is fine.when i go through the phone, the ethernet connection goes up and down every couple seconds.
Hi Guys, I have a set up that i'm required to configure an analog Polycom conference soundstation 2 with UC540. I am able to configure it to make calls and receive but i can't seem to add a third caller for a conference call. Practically i can't make...
I'm trying to setup my UC520 to support overhead paging. I have a Yorkville/Coliseum CA1 Amplifier. On the back is has a telephone paging connections for tip/ring. I plugged that into my UC520's FXS port and assigned an extension to it. When I ca...
I am a complete noob to cisco cli, I have purchased a uc540 from ebay that appears to be defaulted.Cisco UC540W-BRI-K9 (MPC8358) processor (revision 0x100) with 249856K/12288K bytes of memory.Installed image archiveProcessor board ID FHK1420775QMPC83...
Hi Community, I tried different options to register SPA504g with Software Version: 7.5.2 as SIP phone in cucm 7.1.5 but failed.I wonder what is missing from mandatory configuration from phone. Also if there is a way to create auto registration for...
Hello,how is it possible for one line (not for all) to set up a permanent suppression of the Caller ID. I can not find it in the settings. I can find only the suppression of all line. Who can help me?regardsDaniel
I haven't found a Cisco device that does what I'm trying to do, but maybe they have one I missed or maybe someone knows of a different place to look for a solution.I have a lot of interference in the 1.9 GHz range so standard cordless phones do not w...
Hi experts Is there any feature/XML application to lock the device?As far as I know, although not familiar with this type of devices, we can use Extension Mobility but my customer is looking for a more basic application to lock the device and unlock ...
Hi, I bought few years ago Cisco ATA 188 , but never really used it, I installed it properly to Router, Computer, phone then I got dial tone but it does not work because I did not installed any software, I believe I need Call Management software, th...
Hi ThereI have a PAP2T here and a TG582n ModemLooking to use Sonetel as a Voip provider. It all works fine on a DSL G604t modem, but with this one, theres only one way sound ( I cant hear the other person ) I have tried some port forwarding and all b...
