Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hello,I am fairly new to PBX system. I have recently set up a UC320W with an external SIP trunk. It seems to be registring with the SIP provider correctly and I am able to call in with my cell phone and it gets routed correctly to one of 3 SPA504G ph...
Hello,We have two sites each with a UC520 – HQ and Branch. Can they be set up so the HQ has SIP to our Telco provider for PSTN access and the branch uses the SIP connection from the HQ over IPSec?Also our CEO needs a phone at the branch with his HQ e...
inewman by Level 1
  • 2235 Views
  • 11 replies
Hi All, I  have a  SPA112  brain new,  with  latest  fw  loaded as  per  Cisco site  Version 1.2.1 (004)Since  the  first  installation  has  started to  show  the  same   problem as  described  also  in " SPA112 Crashes - No dialtone, restart needed...
Does anybody know how to configure the 3CX soft PBX so that the MWI works properly on the Cisco SPA303 and SPA 525G phones?I find that if you set Message Waiting on any extension in the phone's web interface to "Yes" the MWI comes on and stays on whe...
Good morning, I've a spa502G phone and  cme 8.0.The phone is compatible with my cme?If yes I need to have the phone firmware but I'dont have access to download firmware from the cisco webasite, Anyone can help me?Thanks in advanceGiancarlo           ...
How to configure Cisco SPA8800 connectivity to Lync Server 2010. The entire infrastructure are compose of Windows Server 2008 R2 64-bit as AD with Hyper-V of Exchange 2003 on a Windows 2003 Standard 32-bit, Lync Server 2010 (all are colocated) on Win...
I am sending logs to my syslog server from my SPA122 but also want to be able to view them on the device in the case that there's a device issue and it can't send out to the syslog server. If I were to log kernel & system in the "Log Module," what's ...
New unit with latest firmware (1.2.1).  SPA112 qualify response times are usually between 48-60 ms (my polycom phones are 5-6).  After some number of hours, it suddenly won't respond to the once a minute asterisk qualify and returns very long respons...
First off can users with SNR or shared extensions work with ACD?  I'm following the guide but can't get anything to work.I made a basic ACD called 515 as the pilot number with all basic settings and put 2 of my extensions as members.  I then put on m...
I'm testing an SPA112 with firmware version "1.2.0 (042) Jul 5 2012" to see if some of the previous DTMF issues have been resolved.We have analog devices sitting behind the ATA that require DTMF tones to be played for at least 1 second to be acknowle...
Hi, i have the following questions, hope you help me to figure i out what to do:Im trying to establish a vpn connection betweeen a UC540 and my remote pc for support throu CCA 3.2. The UC is managing an ADSL connection with PPPoE. Everything great so...
We use SIP Trunks on the UC520 and they work fine, call quality is great.  I just set up Live Record as that's a handy feature, however whenever we do it, as soon as the conference starts, the call quality sounds a bit worse.  It's not choppy as in i...
Hi All!I have not sure the step by step in procedure to upgrade UC540 due a bug CSCtt94391 and I didn´t find related documents with step by stepa) I Just download the pack 8.6.2 included many .tar files and not any .bin image. Only near a IOS Image f...
