Here is what I would like to do. Setup outbound caller ID for specific extensions. Example x4400 has inbound DID of xxx-xxx-4400 I would like for when this phone makes an outside call the receiving party sees xxx-xxx-4400 on his or her phone NOT or...
Hey guys,I am putting together a site for a customer with a UC540 (8.0.2) behind an SR520 (12.4(24)t3-ADV-IP-SERV-CRYPTO). Everything seems to work great in passing data through, but voice is a no go. From my experience with the SA520, I had to cre...
DID recieved digits 2324 go to blast group 511. DID recieved digits 2325 go to blast group 512. Need a way for users to view which blast group is ringing.I know you cant show which channel is being used on PRI. Just want to show which blast group is ...
This wasn't a problem at this site when we set it up but now every call has a 20 second delay before it begins to ring. Looked at a debug and saw out of sequence packets and packet queue overflow but I am not sure if this is the issue. Whatcan I test...
Having issues with the standalone operator console program at the radius screen. The program does not seem to be able to setup radius, even though it downloaded the router config, phones etc fine.I tried setting up radius server deatils at CLI level ...
Hi all.We have a UC520 with the optional T1\E1 card installed and an ISDN30 line attached. I have tried setting up the caller ID via CCA and CLI but I cannot get it to work. We have 20 DDI's available with 11 in use at the moment. The only number tha...
Is it possible to forward calls from an AA to shared lines? Is it possible for shared lines to be part of a hunt group where if AA transfers a call to a hunt group of shared lines and one or more of those shared lines are busy, the next free shared ...
From my ISP, my connection goes to an ASA-5505 and then on to my UC540. Behind the UC540 is a Windows server running DHCP. I want VPN users that connect to the ASA-5505 to get IP addresses from the Windows server.I had this working last week after ...
We have a UC520 connected to a AT&T SIP trunk and have a fax machine connected to one of the FXS ports. We are able to send faxes but we can't receive faxes. Here is what I have in the config file:voice translation-rule 8rule 1 /0741/ /0741/!voice ...
We have run into a situation, where if the 2 receptionist phones are using both lines alotted to them, the caller gets put in an Auto-Attendant that prompts them to press1 to leave a message in the General MailBox or continue holding for the next ava...
helloWe have setup a uc540 with the ISDN and WAN connection however we have multiple server to connect via our gigabit ws-c2960g switch, all our users use thin client terminals to access VM View 4. Each thin client terminal will be plugged into the p...
We have a UC540 all working well but i have one problem if i make a call from ip phone to analog phone(FAX) a take a busy signal.If i make a call from analog phone(FAX) to ip phone all working well.Can anyone see a problem with this config?Thanks,
We set up a new customer on a UC560. and we're getting ready to implement a site to site to their branch office.Meanwhile, they decided they don't want to dial 10 digits and want the 7 digit dialing.I know we can change that in CCA, but is it really ...
