Looking for installation and deployment guides for the BE6000S. Does anyone have them? Unable to find any technical docs.
Hi, I'm pretty new for CISCO ip phone. I've got CISCO SPA502G and SPA504G handsets and want to setup in my office. All handsets in the office are Polycom IP 330 and 331, I'm replacing them to CISCO ones. They were previously used in other company. ...
It appears that SPA525 phones on wifi can originate group pages, but they don't receive them. Is this a known limitation or a bug? In either case, is it something that will be made to work in the future?
Hi, Could anyone tell me if/how you change the default IP address on a SPA112? I have a ATA that needs to go into a 192.168.15.0/24 network, but when I try to set the IP address as 192.168.15.240 it says "WAN and LAN are the same , please check" and...
Dear community Just bought a SPA 112 that seems to be working just fine, apart from one thing: We can't seem to place local calls between the two lines (long cable between two buildings). It rings but goes quiet and hangs up after making a call and ...
Hello, I have two SPA525G2 on the same location who start to have the same problem since a couple of months: When the sound comming out from the speakerphone is to loud or too actute, the phone reboot. It's may come from a ringtone or during a call o...
Hi, I am having an issue with transferring calls from a single SPA525G phone to any of our other SPA514G phones. Not every time, but maybe every second/third time the phone call drops out once the 'transfer' button has been pressed the second time t...
Hi,I've setup a new UC320 after ungrading to 2.1.1 and all works fine except the 5252G2 resets approx every 2 minutes with this diaglog on the screen. I have not tested this phone on a previous version of UC320 software."Refreshing voice component"Th...
Hi Everyone, Can anyone guide me through for the installation of Cisco SPA112 Fax adapter in detail.I have cisco call manager i want to install fax adapter using with my DID. Please give full steps including what changes has to be done ...
Hi, I have two SPA504G phones which i'd like to configure so that they both have access to the same two DIDs. I have been trying to achieve this using Shared Call Appearance. I can configure the phones without Shared Call Appearance so they both h...
We recently had our vendor install a new Cisco based IP Phone System using Cisco switches and Cisco SPA514G phones. Calls that are made internally sound tinny or sound like you are in a tunnel. Would like some help determining a fix. Thank You!
Greetings .. Actually I am looking for easy example configuration to expand 2 PSTN lines from main branch to another branches. as each line should be dedicated for particular side. please have a look to enclosed example.
Hi - I'm having a problem connecting a cisco SPA525G to a unifi wifi system. It will connect if the system is "OPEN" but not when I have WPA(AES)
Hi, I recently upgraded the firmware of a dozen of SPA112 to 1.4.1. All worked fine except one. This one, even after a power cycle, always reports "upgrade failed". It shows the following system information: Model: SPA112, 2 FXS Hardware Version: 1.0...
