Webex Devices
お世話になります。ウェブエックスを持ち、ウェブエックス、ク、2.、2人の人々の取り付けに関する1人は問題無く、音声・カメラも使用出来たのですが、もう1人のみ音声・カメラがNGでチャットのみが使用出来る状態でした。(ゲスト名は表示され、ログインしたようには見えるのですが)何回か再ログイン頂いたのですが、改善されません。先週には同じ方が普通にログインし、音声もカメラも問題無かったので原因が不明です。お手数ですが、想定される原因などがございましたら、ご教授頂けますと幸甚です。何卒よろしくお願いいたしま...
Hello, I purchased a webex board second hand that did not come with additional service or subscription to anything Cisco related. My board is now stuck in maintenance mode and one error reads "cannot load software". I do not have a service contract w...
We are currently needing to join a Webex meeting outside of our organization from one of our conference rooms.  We can dial in and enter internal meeting ID's with no issue, but we are unable to utilize an external ID.  The only work around I have be...
rpk2012 by Frequent Visitor
  • 1215 Views
  • 2 replies
We are in the middle of cloud registering our devices and have come up against an issue with a couple of devices. They are registered fine and look like they should work etc. However when we try and dial into the Cisco CVI service the behaviour is ex...
ben.huson by Community Member
  • 716 Views
  • 0 replies
Hi, I've setup a room kit pro and the inputs that appear at the bottom of the touch controller unit out of order of the way we would like it setup.  Is it possible to re-organize them through the web portal, control hub, or on the controller itself? ...
I'm using Jlab play as the headsets, it is a Bluetooth headset that works fine in other applications, such as youtube... But in Webex, it produces no sound despite that the Webex recognizes the connection. I can still hear some warning sound from Web...
Do I need a service contract just to get software for my Webex Board? Right now it is stuck in "Maintenance Mode". Is there any other way to get software without a service contract?
We are using Lightware equipment with a Cisco Room Kit Mini with the configuration software online. We keep getting this warning and we're not sure where it's coming from. Has anyone else seen this? "Internal xapi access was requested. This feature i...
