Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Good day, now settled into our new Cisco network equipment, the Access Point WAP321 Wizard is configured with no additional settings for security, the Laptops (Windows) and phone (BB) connect with no problem and no faults or disconnection problems, h...
Hello,we need U-APSD (a special WMM Feature).Does the WAP321-E-K9 Support this feature?We need it for powersave mode from cordless wlan phones.Best Regards,Cornelius
Hi,In our office we have 2 WAP4410N for our clients and guests to have free wifi.One WAP is connected directly to our ISPs Modem/Router. (reffered to as WAP1 from now on)The second WAP was not connected directly to the network. (reffered to as WAP2 f...
My WAP4410N AP is running version 2.0.2.1 firmware which is quite old.There are newer firmware releases available which I'd like to upgrade to (fix the known bugs, etc.).So I upgrade my firmware from version 2.0.2.1 to any of the following versions:-...
I am receiveing these messages on one of my WAP4410n wireless units. Can you tell me what the messages mean? Am I having a hardware issue? My unit is out of warranty. Should I replace the unit?May 10 20:38:19 kernel: ath_bstuck_tasklet: stuck beacon...
Hi,During an update of two WAP121s to firmware version 1.0.3.4 (currently the latest) the network connection was interrupted and they both now seem to be similarly unusable. The wireless lights on both are now unlit, the ethernet lights flash when p...
HI, I want to use the management VLAN254 for my 4 WAP321. but after changing the management vlan in the unit from 20 th 254 I lost contact with the unit.The switch I use is a Cisco 2960. Here's the config of the port : interface FastEthernet0/23 swit...
Hello Everyone,I'd like to set up a 2.4Ghz and a 5Ghz SSID at the same time, using one Cisco AP541N-E-K9. But I can't figure out any way to do so. Is there a possible way?Kind Regards
I am struggling to remember how to configure a small biz client of mine who just purchased four of these WAP321 APs. They want to have two SSIDs one being for private LAN access along with internet and one that can only access the internet. With that...
We have finding the projector in the network. When we connected a Epson projector and a laptop in different access points in wireless, we can found the projector in the network. But when we connected them in same access points in wireless, we can't f...
I purchased 3 of these Wireless-G access points and none of them are plug and play. I am here because I have spent the last three hours trying to go through every step they suggest in the Quick Start Guide.I tried entering in a we...
Cisco Wireless LAN Controller Failover ProtectionIn multiple-controller deployments, if one controller fails, the access points perform the following tasks:If the access point has no primary, secondary, or tertiary controllers assigned or if its prim...
Hi all,I've a WRV210 Wireless-G VPN Router with RangeBooster, that logs this alert almost every time, "Packet type : 0 -- free socket buffer only".Also each time that some devices, like Android, are connected to the Wifi, the wifi starts a reboot and...
I'd like to filter traffic on certain ssid on wap121. I want that clients will be allowed only to access certain services, such as http, https, pop3, smtp, imap. I have tried with setting up access list/ class map/ policy map configuration in Client ...
I noticed the recent post concerning the upcoming firmware for the WAP4400N, and so I'd like to ask the same question for the WAP4410N. It seems that firmware 1.0.12 has been around a long time, and has some distinct issues. May I ask the current tim...
