Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have a Motorola Surfboard Modem connected to a Netgear 24-port switch.I bought the WAP4410N to provide wireless connectivity from the switch.All my PC's can get perfect connectivity via the switch but none of my wireless devices can connect at all....
Our wireless environment consitst of 5 AP541N's configured with 2 VAP's. 1 VAP is for our private network and the second for unsecured guest access. I am wondering what the preferred wireless mode is to maximize network speed? We only have N devic...
HiI have dell inspiron 640m with Wireless 1390 WLAN Mini-Card and it is connecting perfectly with any other routers.but i can not connect it to CISCO WAP4410N router ! i tried several times but no way.I can connect IPAD , Samsung Smart tv , Denon net...
WAP121 We have configure couple of WAP 121 device with configuration and there was a power glitch , it got reset by itself, pls
Hi We have windows 2008 AD and as a radius server and XP as a client. We have wireless infrastructure in place.We use Cisco 4400 Series Controller and 15 cisco wireless access points in our organisation . The client were connecting automatically ...
Hi All,Just got several of these Cisco WAP121 AP's and today had a nightmare with one of them. On one of our areas with no broadband access we have installed the "Globe Surfer 3+ 3G Router" which incorperates its own Wireless AP.I needed to get dec...
Hopefully simple...I need to set up my RV180W with 2 SSIDs, One of which should be set for N-Only and 20/40Mhz (99% of the devices on my network are N) and the other should be G-Only 20Mhz for those 2 devices that cannot support wireless N. I also n...
Hi,I just wonder if somebody can help me. As I had problems with Cisco 4410N in bridge configuration, I was advised to use WAP321 instead.My question is about coverage, I have never used WAP321 so not quite sure if has stronger or weaker signal in co...
When I connect to WAP321 only connects at 130 Mbps. Why?
Hi, i am trying to expand the wifi range of my WRVS4400n. Since the WAP4400 is'nt available i got me a wap321, since it was mentioned as recommende replacement. However i am having trouble in getting the bridge to work.First i tried to use WDS but th...
Hi there,I currently have 3 WAP4410n's (actually, they're WAP4410N-E V02s) that have been really unreliable since I got them - so much so that we've had to cron a restart script on another server which is frankly ridiculous - they've always run firmw...
Hi,I have been using WAP4401N for almost a year in our office and I’m very happy of this device, never had any problem. So I bought 3 new ones for our customer which supposed to work in configuration below:Network ----- AP1 –Bridge mode ----- AP2 – B...
I have owned one of these for about 2 years now, and have sold many of these to clients. Luckily, none of them get used too much as they require constant rebooting, and it would appear as though all versions of the firmware are unreliable. Some sim...
Hello,I would like to provide WiFi in a big house of 4 floors so I have installed 1 WAP4410N wired to the Internet router to act as access point and I have configured 3 others WAP4410N as WDS repeater of the first one.In the first one (the AP), I hav...
Hello,I plan to use the WAP321 as a WLAN Hotspot. But I need more than one AP. What is the Design for this? Do I need to configure every WAP321 with the captive portal and the user need to re-login every time they roam to another WAP321?Or can I redi...
