Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I'm new to VLANs and PBX systems so I was hoping I could get some help in setting up a Cisco UC320W with my WRVS4400N v2 router, specifically connecting to a SIP trunk and with IP phones. I am able to get the UC320W to work if I bypass the rout...
I'm looking for support on why I'm always loosing my internet conection due to my WRV210 Router. This is being used in a business, and it has the most up to date Firmware, I'm also using a spliter hub which was making things work better, but now it s...
I have WRVS4400N as my main router which is connected to my cable modem. I also have a WAP4400N which I wish to have in another part of my house and connect wirelessly to my router. Here is what I'm trying to do. 1. have my WRVS4400N into my cable mo...
Hi I have reciently purchased 7 x WAP4410n access points to allow my users to access the network via the RADIUS server (NPS) on my windows domain.These access points seemed to be the perfect solution but have been nothing trouble.The users have a var...
Hallo,I use Cisco WAP4410N in client/repeater mode. My PC have connection on WAP4410N, and too WAP4410N have connection on Wireless network. I can configure WAP4410N from connected PC and too from Network. But my PC havn't connection on Network. IP a...
Hi!I received my RV180W & started configuring it via web interface.For test purposes I have it connected to a home broadband router (10.10.7.1). I entered a static route in the RV180W which is on the 10.10.10.x. The RV180W WAN port is getting an IP i...
Hello community,I hope one of you can help, I mistakenly mis-configured "Management ACL mode" on my AP541N.Administration>Administration Access Control>Managment ACL ModeI set this to "Enabled", the problem is I only entered 1 IP address, and that IP...
Hi all!I'm newbie on this forum.I have two little buildings. I need to create a single network in each place.In first building I have primary AP with SSID "A", in the second building I have second AP with the same SSID.I try to setup primary AP like ...
I've got a customer looking to deploy a few WAPs. I noticed the WDS feature provides seamless roaming. Both WAPs will be PoE based so I do not need the wireless bridge feature as it seems redundant. What is the best way to deploy these to present ...
Hi from a newbie,Assuming they are suitable, I want to use one (or two) AP1232AG-E-K9 access points for Internet connection through a public wireless network (BTFON), where wire broadband is not an option. I've downloaded what I think is the correct ...
Hi all,I need an Wireless Access Point.Two SSID simultaneously in different IP Rangeit is with a simple browser GUI to manage? (not console and controller)a distance of about 50 (we can place multiple APs)N speedDual BandWhich series meets the above ...
Hi therecan anyone help me with this error message Received invalid EAPOL-Key MIC (msg 2/4) .Time Stamp Severity Service Description Nov 5 2012 15:11:27 warn hostapd[4365] Received invalid EAPOL-Key MIC (msg 2/4) I only get this message from ...
Good Day,I currently have two AP541N access points. Both are configured for internal access and one unit is configured with a Guest VAP. I want to configure the Guest VAP to redirect to an authentication page so that the user connecting has to log ...
Hi!I used to have a DLINK router which covered my whole house with its Wifi signal. After upgrading to the SRP541W router, only the very close vicinity of the router has any acceptable level of signal to use devices. I seriously need to improve WIFI ...
Hi Guys,I have 3 ap541n's in a cluster. I have upgraded 2 of them to 2.04 firmware. The third did not take the upgrade well and hung during the process. I have tried factory reset it but to no avail. Are there any suggestions as to where I can go fro...
