Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi, we have two WAP551 AP's in our main office. I configured them using Single Point Setup, so they have the same information for the SSID's. The issue is that one AP seems to work fine but if I move in the range of the other it won't authenticate,...
There seems to be no 'save' to save the current running config - is that right? The docs say "For example, if you made changes to the current configuration but forgot to save it, after 24 hours, the device automatically saves the currently-running co...
Hi everyone, I am trying to discover a 2500 controller on 1532I AP but is getting failed. Attached are the log messages. Could anybody please help. Thanks.
I have 4 WAP4410N mode AP with WDS. WAP4410N drop the connection, and traffic on LAN is abnormal - sometimes overwhelm all LANAlso communication betweene APs in WDS hang.I try Regards firmware 2.0.7 and also 2.0.6 - is the same !Jaro en → skfirmwar...
I hope the community here can help and suggest a device or range of devices, there appears to be a variety of terminology used aka Client Router and WISP router. The methodology has been proven using a non-cisco WISP router (TP-Link TL-WR843ND) but I...
Hi I'm looking to indentify the cause of an error 17 disconnectionTime Stamp Severity Service Description Mar 27 2014 12:21:21 info hostapd[1301] The wireless client with MAC address a0:88:b4:4a:26:b8 has been successfully authenticated. Ma...
Hi,I just recently installed a brandnew WAP 561 as a main AP on my network but I have trouble getting a good connection speed and transmit rates from it. This is especially true on the 5 GHz band where I used to get a connection speed of 450 mbit/sec...
Hello, I hope to get an answer in this forum. I am waiting for a callback of the telephone support over 1,5 weeks.I have a restaurant and need an Acceess Point with a wide reach and perhaps a switch for 2 things: Guest network for internet and the mo...
Hi to all I recently purchase a Wireless Access Point (AIRCAP 3702E-E) with 4 antenna, i will use this device like wifi hotspot in my home.I would like to upgrade it but i see two kind of AP IOS :Lightweight AP IOS SoftwareAutonomous AP IOS What are ...
Hello,I just purchased 2 WAP321s and I am not able to access them in order to set them up. When I initially plugged the first one up and downloaded 'FindIT', I could see the WAP321. I tried to set a static IP and every since then I have not been able...
Hello,I have a wap321 with firmware v 1.0.4.4. I cannot find any DHCP Server options on the web management portal.Does this device have a DHCP Server, or does simply pass DHCP up to the switch that it is connected to?Thanks
We have one WAP321 which stopping responding after being online for 24hrs. Currently we are just rebooting the device to get it up and running. However I would like to find a permanent fix.
Hello guys,first of all, I must precise that I am French and that my english is not perfect. I hope you will undesrtand what i say I bought a Cisco WAP200 two years ago and I am encountering a problem since then.Every hour or so, the Wi-Fi signal see...
Hi @ Support Community, i bought a Cisco WAP312 Wireless Accesspoint for my Home Office.The setup of the device was not a problem...but... a few days ago i wanted to switch from 2,4 Ghz mode to the 5 Ghz Mode,and it won´t work.The wireless symbol on ...
