Data Center Switches
Hi,Here is the premiseLeaf 1 sends a route type 2 update with standard community to leaf 2 (border leaf) and then this /32 is redistributed into ipv4 vrf and advertised outside of EVPN fabric. The issue is with standard community, it's being stripped...
shados by Level 1
  • 59 Views
  • 2 replies
Hello,I have some nexus 93180lc-ex switches and while looking to upgrade to nxos 10 I found out that these switches are not supporting the 10.x version. Is there a specific reason not supporting this version? Hardware wise are the same with the 93180...
ez9 by Level 1
  • 57 Views
  • 1 replies
We have a Nexus switch - N9K-93180YC-FX - that is connected via 10G uplinks to multiple routers/switches, and it is connected to a certain router using a 1G interface.We need to limit the 1G interface usage for a certain subnet that traverses this 1G...
I am planning to upgrade my C93180YC-FX3 switch from version 9.3.8 to 10.3.3. but during the upgrade process I get the message "Return code 0x40450037 (Not a valid nxos image)". I have confirmed that the nxos64-cs.10.3.3.F.bin file md5 is correct. At...
id404 by Spotlight
  • 3168 Views
  • 3 replies
Hello everyone,When you redistribute hmm into ipv4, these routes are advertised to other leaf switches, resulting in two routes installed in their respective ip-vrf. Something like this:BGP routing table entry for 192.168.10.11/32, version 6Paths: (2...
shados by Level 1
  • 113 Views
  • 0 replies
  • 1 Helpful votes
