IP Telephony and Phones
Labels
Hi,Our management want to put the user's name on their phones now.Is there any way I can edit the line text field for 500+ users using BAT and a  csv file.Or should I manually put the name in the line text field for every line.Thank you very much!!!C...
Hello, has anyone seen any issues with the wireless mics paired with an 8831 unpairing themselves spontaneously?   I just had that happen and it took several tries to get them paired again.  Hoping this was a fluke and not happening on a regular basi...
Hi there, I'm working with a SIP service provider on a new SIP Trunk. When I don't use MTP, I have an issue with Consultative Transfer,  Early Attended Transfer and  Blind Transfer. But when I use MTP all three transfer types are working. Is there a ...
Hi everybody,I have a big problem with a router Cisco 2911 and BRI from Maroc Telecom.I have this status for my BRI :---------------------------ISDN BRI0/0/0 interface        dsl 0, interface ISDN Switchtype = basic-net3        L2 Protocol = Q.921 0x...
Hello,I am currently have the issue is not display original dialed number when forward a call to external number.Example:          External number: 1111          Main line number: 2222          Internal number: 3333 (set call forwarding to 4444)     ...
TAN VO by Beginner
  • 13901 Views
  • 23 replies
Greetings,We are experiencing an issue with multiple VG224s when attempting to raise the voltage level. Every port / gateway is working properly before applying this command. After issuing the following cmd all ports on the analog block  enter a fast...
tjohnson by Beginner
  • 277 Views
  • 0 replies
Hi, I'm having a funny issue with my VG224:Port0 delivers something like -38VDC, same is true for other pairs (Measuring directly on Pins 1/26 that are on opposite sides of the RJ-21 connector). However, Port 3 (Pins 3/28) delivers only -19VDC, same ...
d.haeni by Enthusiast
  • 3150 Views
  • 5 replies
Hi all,We are trying to get an older Spirent Abacus 5000 call generator to connect to one of our 3845 router gateways.Initially we had tried to use MGCP with the backhaul to CallManager, but we were only able to get the port to be active at Layer1.  ...
andy_vvc2 by Beginner
  • 336 Views
  • 3 replies
