Intercluster Trunk between Be3000 and Asterix.
Hey Guys,Is this possible to achieve with be3k at one end ? ThanksVaradarajan.R
I have a questing regarding DL licenses. We have CUCM 7.1.5 and we were using DL licenses. Now i need to buy licenses for 50 third party basic phones and i wonder can i still buy DL licenses or only UCL? What kind of UCL licenses do i need? can i use...
Hello Everybody,I wan to know if it´s possible with the option "CME SRST", to register phone in a CUCM cluster? Or the CME works as a separate Call agent.
Hello,I am little bit confused for CUP 8.6 License, I have a PAK for 8.6 when requesting License from cisco I should provide a MAC of CUCM or CUP server.???In the below link it is showing me the procedure for installing LIC in CUCM and CUP both, so...
I upgraded our UC 560 to the 8.6.2 software pack last week, and it seems the mechanism to have people enter a PIN for long distance calls stopped working.After some intensive research of the configuration files, I've found the cause and a solution......
Good Morning,I'm setting up IP trunking from our Avaya systems to our Cisco systems, but I'm running into issues with the Unity integration. I call the extensions at these sites (from Avaya), and have no problems if they are answered. If the Cisco ...
Hello, in a single site topology, If I have a single gateway router with both voip and PSTN interfaces, is it correct to implement "preference" values within the dial-peers as a form of fallback ?For instance, If I want to use a voip dial-peer as my ...
HelloThe next saturday I had a replication problem with a server in a cluster. I dont konow exactly what was the reason of this failure. Somebody can help me ?The logs in the server are these.Jul 3 01:48:25, MX-BOS2-CCM05, Critical, Cisco Database La...
Hi all,I'm looking for some Cisco documentation or confirmation as to the pin out details for the headset wiring on a 7960G. The closest I have come so far is at this site, but I would just like some Cisco documentation to confirm.All I can seem to f...
Hi All,Need your assistance ASAPWe had a primary and secondary router failed and OBS have now bring back the Primary router, our voice gateway is up but call manager is not reachable and hence all the phones are un-registered. Publisher is not reache...
What's the secret to administering call manager from your Android Phone? It would be great to be able to do minor line tweaking when on the road withouth having to reach for my laptop.Disregard.....Firefox for Android took care of the problem.
I am upgrading from UCCX on vm version 8.5.1.11004-25 to version 9.0.2.11001-24 and im getting the invalid upgrade. Name does not match any filter pattern. Im not sure what this means.. can someone help me out?? very much appri...
Hi guys,I hope someone can help. I have a sip trunk from cucm 9.1 to a 3rd party PBX vendor. Calls between the CUCM and PBX works well, but if the PBX tries to transfer the an "internal PBX call" to me. I get no speach.If you look at the CUCM trac...
Good afternoon all,anybody can suggest the best wey to gracefully restart a Gateway inside a Route Group.The Route Group has 2 GW so idealy we would like to issue a command that would move all new calls to the other GW and as soon as existing calls a...
Hi,I have configured a Communications Manager 9.1.1-20000-5 version with two different H323 gateway. I have configured these gateways in the route group with a Top Down as Distribution Algorithm; without any changes or problem the outbound calls bypa...
Subject | Author | Posted |
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM |
User | Count |
10 | |
5 | |
5 | |
3 | |
2 |
