IP Telephony and Phones
Labels
Hi Guys,here is the configuration that is running in my organiztion.as there is two call legs in each call and every call leg has to match dial-peer,as i didnt understand in the configuration below, call from cucm matches which dial-peer or it matche...
Hi All,The call is dropping if i choose My Personal Recording in Callers Hear field but if i select System Default Greeting the call is working and we can leave the voice mail. Please help.Note :  The greeting which we try to palying is not record th...
Hello Team,does anybody know a document describing CUCM features which are transparent for the users on different CUCM clusters, which are connected through a Intercluster-Trunk. Of course, this might differ for the various CUCM versions.best regards...
alf by Level 1
  • 441 Views
  • 1 replies
I have a CUCM 7.1(3) cluster.  We are experiencing problems with Ad Hoc Conferencing.  When all (3) IP phones are in the same Device Pool (A-DP), it works fine.  However, it has to be in this particular Device Pool (A-DP).  But, when you put the (3) ...
Hello all,I did an Update from CUCM 7.0.1 to 8.6.1.20000-1 and have now a problem with some incomming ISDN calls. I have a H.323 gateway to PSTN with IOS 12.4.24T5.Calls from Telekom or Swisscom as Serviceprovider are working without any problemsCall...
m.ranger by Level 1
  • 8139 Views
  • 22 replies
Let's say I have two sites. They dial each other over a WAN with e.164 numbers (including the leading + symbol). If I'm in one site and call someone at the other site and they don't answer, how will my number show in their missed call list. With the ...
Ive got a user that randomly when someone calls from the outside it goes straight to voicemail.  internal calls work fine.  Ive tried swaping phones, patch cables, deleting the DN and ephone, etc.  The account is setup exactly like everyone else in t...
lukeprimm by Level 1
  • 1073 Views
  • 0 replies
Any idea how I might get a 7912 set to take the configuration I have setup in CallManager rather than seeking to auto register?  I have tried both of the following suggestions, but the phone always reboots to 12:00 a 01-01-00 AUTO-REG.Step 1 Press th...
4bsmith by Level 1
  • 524 Views
  • 0 replies
