IP Telephony and Phones
Labels
Hi,I am trying to convert a cipc running sccp to sip.It attempts to download and install locales, however I get the following error message:English_United_States/CIPC_Locale.zipCould not download fileDownloadfile:tftp -i ccm7 GET English_United_State...
PAUL CHEN by Level 1
  • 905 Views
  • 0 replies
Hello.I'm looking for a following step-by-step guides:1) How to register Cisco IP Communicator with Cisco Unified Communications Manager 62) How to register Cisco Unified Personal Communicator with Cisco Unified Communications Manager 6Thanks in adva...
Hello all,As mentioned above i have a requirement to connect our current OCS infrastructure to our local PBX (Nortel BCM50).Now the BCM50 doesn't have v3 of the firmware which would allow it to establish a direct sip trunk to the OCS server and it on...
Hi,I have an old MC3810 with 2 FXO ports connected to FCT's for mobile calls. This works fine. When we can this FCT, I am sending the call to the CM (6.1.3) that connects it to an IVR. This works fine. What doesn't work is the DTMF tones. The are not...
Hi all,We are looking to integrate our current PBX Meridian system with our Unity solution. My question is; will the message waiting indicators still work on our Meridian numbers while integrated with Unity?Thanks
jamieparr by Level 1
  • 446 Views
  • 4 replies
Hi,We are using CCM version 5.1.3 which says that CDR are automatically backed up through DRS.There is no need to select CAR/CDR feature to backup this data. IN DRS, we get option of CCM feature only.After the backup is taken successfully, I do not g...
amansoi_5 by Level 1
  • 1233 Views
  • 1 replies
I would use SNR to have my IP Phone and my mobile phone ring simultaneously. Everything is setup and works fine except one thing.If my mobile phone has not taken the call after 20s, it should be connected to the voice mail of the mobile, but the gate...
