IP Telephony and Phones
Labels
Hi, iam trying to setup the cme gui and have downloaded the ios and the correct gui files.However there seems to be missing the ccme.html file.I have checked a few other versions and it is missing from those aswell.Is this right as i'm sure i've done...
m.batts by Level 4
  • 1399 Views
  • 5 replies
i have installed CCM 4.2 on MCS 7845 H2....now when i go to service activation and try to activate any service(including call manager) when i click update nothing happens and on th eleft hand corner i see error on page messahe that yellow triangle.....
guys i have bars utility installed on my server (publisher) now i went into bars and try to see which server ite which server its is backing upto....not default as of i know so as soon as bars utility loaded th emessage comes "backup or restore proce...
moh
hiin a centralized ccm with multisites environment, i need moh to be played by the remote site's gateway?i need a guidance (good doc) on how to make thisi need a dsp resources on the remote site's gateway? right?please help
I would like to update the following using BAT: Phone Configuration: DescriptionLine Configuration: Description, Alerting Name, Display Name and Line Text.I am planning to use BAT for this, since in total there are 5000 users on the network, but I wi...
amitsonik by Level 1
  • 400 Views
  • 2 replies
Guys,runnning ccm 5.1.2 and am having an intermittent issue with some phones. i have a phone in a hunt and if i change the css on that phone i can make the appropriate calls etc. however, when i attempt to call to the phone it goes directly to the hu...
a.gooding by Level 5
  • 376 Views
  • 3 replies
Hi,I'm trying to connect an analogic fax through an ATA. The gateway is in MGCP mode with SRST. If I can use the fax like a phone but I can receive/send fax with it. I'm attaching the sh run file of gateway, and prserv file with ATA debug.Someone can...
sucr by Level 1
  • 598 Views
  • 2 replies
