Hello,I'm searching for a procedure to enable the both ethernet ports on the CCM5. By Default, the second ethernet port is inactive.Thanks for your help
Hello,has anyone every connected a script to a database in IPCC using a stored procedure to call a package instead of a hard coded SQL query. We have millions of records in the database on multiple tables and cannot use a hard coded SQL query. Nati...
We are trying to bulk administer a customer with over 700 Phones and would like to change their dial plan from a 4 digit to 10 digit. We have been successful in changing the static phones.We do this by exporting the Phone details then using this txt ...
My company purchased some 7940 and 7960 phones. The phones have user passwords assigned to them that i do not have and want to reset them back to the factory standard. Is there any way that this can be done without the passwords?Thanks in advance
Hi I would like some pointers as to the kind of product we would need.Basically we want to take VoIP SIP data and route it out to an ISDN E1. An ideal product would allow for G711 (PCM), GSM-FR and GSM-EFR voice traffic. The intended use is for testi...
Is the newest SIP firmware for the 7940G XML based like the 79x1G series phones?
My 7941G keeps restarting it self after 30 minutes. I don't know what it is. Is this normal? Can it be a configuration error? I'm really stumped as to why the phone is doing this.
We have a 2851 voice gateway that currently runs MGCP for inbound calls, and H323 for dial-peer services to a 4 port FXS module that provides fax services. My request is whether the 2851 can be setup (via H323) to vector inbound PSTN calls to an int...
We are running CCM 4.13SR2. Voice gateway is 2651XM with a 24 Channel PRI running 12.4(3f) which was deferred. I have been to all the Matrix docs that make suggestions but they are way behind the IOS versions which are available for download. Any i...
Hi,Is there a way to block all incoming calls to voice port 0/0/2 and still allow outgoing calls.Please find attached configuration.
I had a subscriber in Orlando (Unity 4.2(1) Voicemail Only) send me a message in Jacksonville (Untiy 4.2(1) Voicemail Only) using Unity Networking (Dialing Domains) on Friday 4pm. He sent me one message (7900 press Message, Press 2 Compose New Messa...
When configuring a H323 trunk between CallManager and a H323 gateway, we can use h245-alphanumeric DTMF relay option. Besides h245-alphanumeric, any other DTMF relay methods appliable? Dose CallManager support rtp-nte in H323 trunk?ThanksHenry
i have cisco 2850 , i need to set calling number to be p-asserted-identity in sip calls and for pstn calls it doesnot change what is the config right now.I am novice to this. I am attaching my config
Is there a system wide timer for the toggle button on the IP Phones for going from off-hook/on-hook/off-hook? I have a customer that, when they're on line 1 with a call and another call is coming in, if she terminats the first call and picks up the s...
We have got CM 4.2 package The package include Extended Service Auto-attendant version 3.5(2) CD & IPCC Express, IP IVR, Q MJR version 4.0(4)We want to install the Auto Attendant on the same CallManager ServerThe problem that we found uncompatability...
Subject | Author | Posted |
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
