IP Telephony and Phones
Labels
Resolved! Hair pinning
Is it possible to configure a hair pinning config where two IP phones try to call each other via the same Gateway without configuring a POTS dial peer? What are the relevant configs for MGCP / H.323 / SIP Gateways?Any help would be appreciated. RS.
First of all, this physical phone belongs to the number ending 7201. After attempting to log in for testing, it changed to the user profile instead of mine. Additionally, the Extension Mobility Service is missing in the user profile with the number e...
FLINZZY by Level 1
  • 114 Views
  • 1 replies
Hi, We have Branch office and Head office sites. At head office, we have Cisco CUCM application running and at the branch office, we have SRST router 1 and 2, both connected to head office over WAN. SRST router 1 should come in to picture when there ...
inhamit by Level 1
  • 164 Views
  • 6 replies
Hi Together,   i'm having problems with configuring BLF on 8851 3PCC with Asterik System. BLF are blinking and when pressed i've getting failure "Invalid Number".   Software Version: sip88xx.11-0-1MPP-477.loads Voice with no problems, Calls possible ...
implec by Level 1
  • 1730 Views
  • 2 replies
